compatable cpu?
  • maddogcsi2004
    • Dec 2015
    compatable cpu?
    Can I change my AMD Athlon(tm) II P320 Dual-Core with intel i3 370m dual core?
    • 969
    No, won't be possible. There are too many differences (socket type, chipset, etc) for you to be able to interchange one processor from one manufacturer with another. Also, you cannot replace most laptop processors as they are typically soldered onto the main board.
