CPU 5930k and RAM Ripjaws4 problem
  • Dido
    • Jan 2016
    I have 5930K fresh Win 7 OC it to 4.6 core, chace to 4.0 ram on 2666mhz
    Operating System: Windows 7 Ultimate Edition Service Pack 1 build 7601 (64-bit)
    CPU Type: Intel Core i7-5930K @ 3.50GHz
    Number of CPUs: 1
    Cores per CPU: 6
    Hyperthreading: Enabled
    Motherboard: X99A GODLIKE GAMING (MS-7883)
    Memory: 32GB RAM
    Videocard: NVIDIA GeForce GTX 980 Ti
    Hard Drive: WDC WD3200AAKS-00L9A0 (320GB)
    Hard Drive: Crucial_CT256MX100SSD1 (256GB)
    Hard Drive: WDC WD30EZRX-00D8PB0 (3TB)
    Stabel with: Aida64, realbench, xtu, hire performence test....
    cpu z http://valid.x86.fr/el378j
    whay i experience this in test
    CPU mark:
    My5930K: 4899
    Random 5820k pc:12868
    Cpu-Prime Numbers
    My :4.20
    Random 5820k: 38.5
    Cpu-physic
    My:93.8
    Random 5820K: 782
    Cpu sorting
    My: 6680
    Random5820K: 10941
    Hire is my baseline: http://www.passmark.com/baselines/V8...id=54366931346
    And memory to sucks!! :O
    Memorymark: 626
    Memory-database operations :33.1
    Memory-Read Uncached: 2884
    Memory Write: 1028
    Memory Threaded: 2367
    Please can someone look in spec and point me where can be problem
    543669
    The CPU tests that make heavy use of RAM have low results.
    And as you point out the RAM speeds are well down on what one would expect.
    So I think the CPU is OK. But the RAM setup isn't. Have a look at the timings, clocks speed and XMP settings.
    • Dido
      • Jan 2016
      Hello. Ram was ok! I RMA motherbord and get new one i just hit 8. place in Top 20 Computer System Benchmarks
      http://www.passmark.com/baselines/V8...id=55306303482
      So problem was MB.
      Thanks for look up
