Compare single vs dual CPU results
  • ramirez
    • Feb 2016
    Good day!
    i need to compare single cpu sustem vs dual cpu system (in my case: E5-2670v3 vs E5-1680v3).
    so, i have question: perfomace score for dual cpu system, is perfomance of both cpu's at same time? or it is perfomance of each CPU in daul CPU system?
    Thnx!
    The multi-cpu performance chart is performance when all available CPUs and cores are used.
    So the dual CPU Intel Xeon E5-2670 v3 benchmark score is 22,953.
    The single CPU Intel Xeon E5-1680 v3 benchmark score is 17,166
    But unless you are sure all your workload is highly multi-threaded then you should also consider the single threaded CPU chart. The single CPU E5-1680 V3 looks much better here.
