Diskcheckup fails on start
  • bruce
    • Nov 2006
    Using Win XP, SP2. Downloaded and installed diskcheckup and when started the system immediately says that diskcheckup has encountered a problem and needs to close.
    The system logs says:
    Faulting application diskcheckup.exe, version 2.0.0.0, faulting module diskcheckup.exe, version 2.0.0.0, fault address 0x00009185.
    and in the next error
    Fault bucket 340850897.
    What to do?
  • sk
    • Apr 2006
    • 16
    Hi, could you please run DiskCheck from the command line with the argument DEBUGMODE. This will create a log file named "DiskCheckupLog.txt" in the same directory as DiskCheckup.exe. Please send the file to me at sk [at] passmark [dot] com. Are you using XP Home or XP Pro?
    SK
    PassMark Software
    • bruce
      • Nov 2006
      Thanks for the reply.
      I am using XP Pro w/SP2.
      I did as you suggested but no log file was produced. Yes, I am looking in the same folder as the program is located. An info box does come up advising of the Debug mode when it is run.
      • sk
        • Apr 2006
        • 16
        I have e-mailed a new debug built to you. Hopefully, a debug file will be created this time and you can send it to me. Please run it on the command line with the DEBUGMODE argument.
        SK
        PassMark Software
