A trivial question...
  • paolo.moro
    • May 2018
    • 77
    I finally managed to convince the company I work for to use the Burning Test program as our sole testing software instead of Eurosoft PC-Check.
    I had them purchase the SITE LICENSES version to avoid any issues whatsoever, since I’m the production manager and we’re a system builder (in Italy).
    My simple question is this:
    Can I continue to request support through my personal account, or is it better to request support as a registered ENTERPRISE user?
    Thank you
    • 968
    Either is fine. If you do send in a support request, just provide your order number and we can look up your support status.
