Raw Read Error Rate
  • trance
    • Nov 2006
    Raw Read Error Rate
    hello,
    I always check my disk with the Diskcheckup and HDtune, but last hour I had a really quick power cut off (about 2s with no power)... the computer reseted and then I did a scandisk (didnt find any problems) and checked again the SMART status.
    But this time I've noticed the Raw Value of Raw Read Error Rate attribute is 1.
    After this I desfragmented and did a surface scan on all partitions to see if the value raise, but it didnt change.
    I also noticed the Spin Up Time attribute has a lower value (normally 5504ms ~ 5568ms), but I dont care too much about this attribute, as the power quickly came, the disk was still spinning, so it took less time to speed up.
    Should I be worried about the Raw Read Error Rate Value or it was caused by the power cut off? I was running emule, IM, and Need For Speed Carbon game. OS is WXP Pro SP2 with all updates installed.
    thanks a lot
    here is the drive info:
    Code:
    Device ID:                      0
    Device Capacity:                6194253374051377 MB
    Serial Number:                  1191J1FA124831
    Model Number:                   SAMSUNG SP1604N
    Firmware Revision:              TM100-31
    Partitions:
        C:                          20481 MB
        D:                          40962 MB
        E:                          91173 MB
    IDE Registers:
        Features:                   0x0
        Sector Count:               0x1
        Sector Number:              0x1
        Cylinder Low:               0x0
        Cylinder High:              0x0
        Drive Head:                 0xA0
        Command:                    0xEC
    ID Sector:
        Cylinders:                  16383
        Heads:                      16
        Sectors per track:          63
        Cur Cyls:                   16383
        Cur Heads:                  16
        Cur Sectors/Track:          63
        Bytes per track:            34902
        Bytes per sector:           554
        Gen Config:                 1114
        Buffer Type:                3
        Buffer Size:                4096
        Vendor Unique:              FFFF 0 0
        More Vendor Unique:         0x8010
        ECC Size:                   4
        Double Word IO:             0
        Capabilities:               12032
        PIO Timing:                 512
        DMA Timing:                 512
        BS:                         7
        Current Sector Capacity:    16514064
        Total Addressable Sectors:  268435455
        Mult. Sector Stuff:         272
        Single Word DMA:            0
        Multi Word DMA:             7
    SMART ATTRIBUTES:
     ID Description                          Raw Value  Status     Value      Worst      Threshold  TEC
      1 Raw Read Error Rate                  1          OK         100        100        51         N.A.
      3 Spin Up Time                         4544ms     OK         100        100        25         N.A.
      4 Start/Stop Count                     204        OK         100        100        0          N.A.
      5 Reallocated Sector Count             0          OK         100        100        11         N.A.
      7 Seek Error Rate                      0          OK         100        100        51         N.A.
      8 Seek Time Performance                0          OK         100        100        15         N.A.
      9 Power On Time                        81072      OK         100        100        0          N.A.
      A Spin Retry Count                     0          OK         100        100        51         N.A.
      B Calibration Retry Count              0          OK         100        100        0          N.A.
      C Power Cycle Count                    100        OK         100        100        0          N.A.
     C2 Temperature                          31 C       OK         145        109        0          N.A.
     C3 (Unknown attribute)                  8467744    OK         100        100        0          N.A.
     C4 Reallocation Event Count             0          OK         100        100        0          N.A.
     C5 Current Pending Sector Count         0          OK         100        100        0          N.A.
     C6 Uncorrectable Sector Count           0          OK         100        100        0          N.A.
     C7 UltraDMA CRC Error Count             0          OK         200        200        0          N.A.
     C8 Write Error Count                    0          OK         100        100        51         N.A.
     C9 Off Track Errors                     0          OK         100        100        51         N.A.
    HDTune info:
    Code:
    HD Tune: SAMSUNG SP1604N Health
    ID                              Current  Worst    ThresholdData     Status
    (01) Raw Read Error Rate        100      100      51       1        Ok
    (03) Spin Up Time               100      100      25       4544     Ok
    (04) Start/Stop Count           100      100      0        204      Ok
    (05) Reallocated Sector Count   100      100      11       0        Ok
    (07) Seek Error Rate            100      100      51       0        Ok
    (08) Seek Time Performance      100      100      15       0        Ok
    (09) Power On Hours Count       100      100      0        81146    Ok
    (0A) Spin Retry Count           100      100      51       0        Ok
    (0B) Calibration Retry Count    100      100      0        0        Ok
    (0C) Power Cycle Count          100      100      0        100      Ok
    (C2) Temperature                145      109      0        31       Ok
    (C3) Hardware ECC Recovered     100      100      0        8468126  Ok
    (C4) Reallocated Event Count    100      100      0        0        Ok
    (C5) Current Pending Sector     100      100      0        0        Ok
    (C6) Offline Uncorrectable      100      100      0        0        Ok
    (C7) Ultra DMA CRC Error Count  200      200      0        0        Ok
    (C8) Write Error Rate           100      100      51       0        Ok
    (C9) (unknown attribute)        100      100      51       0        Ok
    Power On Time         : 81146
    Health Status         : Ok
    I don't think there is anything to be worried about. Sudden power failure are fairly common place, and you haven't crossed the threshold that would indicate that the drive is bad.
    • trance
      • Nov 2006
      that was fast! thanks a lot for the answer! now i'm calmer...
      • FrankyBkk
        • Apr 2007
        I got the same question
        after you got this fast answer from the Administrator here is one of my HDs.
        I have not a good feeling about it.
        I hope to get an comment from the Administrator too.
        SMART ATTRIBUTES:
        3 Spin Up Time 10844ms OK 206 205 63 N.A.
        4 Start/Stop Count 456 OK 253 253 0 N.A.
        5 Reallocated Sector Count 502 OK 204 204 63 N.A.
        6 Read Channel Margin 0 OK 253 253 100 N.A.
        7 Seek Error Rate 0 OK 253 252 0 N.A.
        8 Seek Time Performance 46012 OK 249 232 187 N.A.
        9 Power On Time 19470 OK 208 208 0 N.A.
        A Spin Retry Count 0 OK 253 252 157 N.A.
        B Calibration Retry Count 0 OK 253 252 223 N.A.
        C Power Cycle Count 539 OK 252 252 0 N.A.
        C0 Power off Retract Count 0 OK 253 253 0 N.A.
        C1 Load/Unload Cycle Count 0 OK 253 253 0 N.A.
        C2 Temperature 35 C OK 35 253 0 N.A.
        C3 (Unknown attribute) 21118 OK 253 252 0 N.A.
        C4 Reallocation Event Count 0 OK 253 253 0 N.A.
        C5 Current Pending Sector Count 62 OK 247 247 0 N.A.
        C6 Uncorrectable Sector Count 0 OK 253 253 0 N.A.
        C7 UltraDMA CRC Error Count 0 OK 199 199 0 N.A.
        C8 Write Error Count 0 OK 253 252 0 N.A.
        C9 Off Track Errors 0 OK 253 252 0 N.A.
        CA Direct Address Mark Error Rate 0 OK 253 251 0 N.A.
        CB Error Correction Code Errors 0 OK 253 252 180 N.A.
        CC Raw Read Error Rate 0 OK 253 252 0 N.A.
        CD Thermal Asperity Rate 0 OK 253 252 0 N.A.
        CF Spin High Current 0 OK 253 252 0 N.A.
        D0 Spin Buzz 0 OK 253 252 0 N.A.
        D1 Off Line Seek Performance 165 OK 240 240 0 N.A.
        D2 (Unknown attribute) 0 OK 253 252 0 N.A.
        D3 (Unknown attribute) 0 OK 253 252 0 N.A.
        D4 (Unknown attribute) 0 OK 253 253 0 N.A.
        Nice greetings from Bangkok
        Frank
          Can you elaborate? I mean is there smoke pouring out of the drive or something that you are basing your bad feelings on?
          As you can see from your own results, all the SMART attributes reported, "OK".
          • Vyndrox
            • Apr 2007
            SMART ATTRIBUTES:
            1 Raw Read Error Rate 866 FAIL 1 1 51 N.A.
            3 Spin Up Time 3941ms OK 132 122 21 N.A.
            4 Start/Stop Count 1384 OK 99 99 40 N.A.
            5 Reallocated Sector Count 0 OK 200 200 140 N.A.
            7 Seek Error Rate 0 OK 200 200 51 N.A.
            9 Power On Time 3664 OK 95 95 0 N.A.
            B Calibration Retry Count 0 OK 100 100 51 N.A.
            C Power Cycle Count 1291 OK 99 99 0 N.A.
            C2 Temperature 34 C OK 116 253 0 N.A.
            C4 Reallocation Event Count 0 OK 200 200 0 N.A.
            C5 Current Pending Sector Count 2 OK 200 200 0 N.A.
            C6 Uncorrectable Sector Count 0 OK 200 200 0 N.A.
            C7 UltraDMA CRC Error Count 22 OK 200 253 0 N.A.
            C8 Write Error Count 0 OK 200 155 51 N.A.
            I have this problem since this morning. Raw Read Error Rate Fail.
            What should/can I do?
              Start to keep good backups of your hard disk so when the drive fails you have minimum disruption. This is not the kind of problem that you can fix at home.
              • bluefox21
                • May 2007
                I also wanna hear some answer from this problem of mine which similar to previous post of other members. I just purchase an IDE 320GB hard drive about just 2 days ago but seems that the raw read error rate and seek error rate has some porblems. I'm not sure if this ok or not, or should I ask for repalcement from the supplier or not...
                here the drive smart ino
                SMART ATTRIBUTES:
                1 Raw Read Error Rate 119647723 OK 117 99 6 N.A.
                3 Spin Up Time 0ms OK 95 95 0 N.A.
                4 Start/Stop Count 6 OK 100 100 20 N.A.
                5 Reallocated Sector Count 0 OK 100 100 36 N.A.
                7 Seek Error Rate 1688501 OK 62 60 30 N.A.
                9 Power On Time 56 OK 100 100 0 N.A.
                A Spin Retry Count 0 OK 100 100 97 N.A.
                C Power Cycle Count 8 OK 100 100 20 N.A.
                BB (Unknown attribute) 0 OK 100 100 0 N.A.
                BD (Unknown attribute) 0 OK 100 100 0 N.A.
                BE (Unknown attribute) 840826927 OK 53 50 45 N.A.
                C2 Temperature 47 C OK 47 50 0 N.A.
                C3 (Unknown attribute) 166985206 OK 66 66 0 N.A.
                C8 Write Error Count 0 OK 100 253 0 N.A.
                CA Direct Address Mark Error Rate 0 OK 100 253 0 N.A.
                hope to also some opinion from the experts of passmark.com. Thanks
                  If you had a FAIL for the "Raw Read Error Rate" or a fail for any other value, then you should be concerned and attempt to get the drive replaced if it is under warranty.
                  • bluefox21
                    • May 2007
                    I wonder...
                    Yes it is still under warranty since I just bought it. There's no fail mark in "Raw Read Error " and "Seek Error Rate" it say that it is Ok but the values are very alarming... Other Smart Softwares indicates that the health and performance status of the drive is at 50% only.... my other 2 drives are at 95 and 100%. Only just this new 320gb HD i bought is at 50%.... I'm really confused if I should ask for replacement even the drive is running well, but the performance is very low in percentage....
                    • ricky49
                      • Jun 2007
                      Raw Error Rate
                      HOW DOES THIS SOUND: attribute raw read error rate changes 60 TO 58 . DOES THIS MEAN NEW HDSK ?
                        But just looking at the numbers in the "Raw value" column doesn't tell you much, as these values are determined by the drive manufacturers and the significance can vary from one drive model to the next.
                        More interesting are the values in the "worst" and "threshold" columns.
                        • ricky49
                          • Jun 2007
                          raw read error
                          I'm relieved! But can you tell me why this message keeps popping up? One time 52 to 51, then 60 to 58 or 58 to 57. Does it have anything to do with a programm I've downloaded? Thanks for your information, Ricky
                            What message are you referring to?
                            • ricky49
                              • Jun 2007
                              raw error rate - ricky49
