Reallocated Sector Count FAIL
  • Twoiko
    • Mar 2007
    I just dled disk checkup today when I found it because I noticed that my 4 month old laptop has been going really slow since my reformat. What's been happening is the HD light keeps coming on every 2 seconds or so and I don't know why. I've tried closing all non-essential programs but there aren't many, since it was just reformatted. So, here are the results:
    Code:
    DiskCheckup Version:            DiskCheckup V2.0 Build: 1004
    SmartDisk DLL Version:          SmartDisk DLL SDK v1.0 Build: 1012
    Time of export:                 17:05:38 18-Mar-2007
    Device ID:                      0
    Device Capacity:                76316 MB
    Serial Number:                  5PK1YTPT
    Model Number:                   ST98823A
    Firmware Revision:              3.05
    Partitions:
        C:                          76308 MB
    IDE Registers:
        Features:                   0x0
        Sector Count:               0x1
        Sector Number:              0x1
        Cylinder Low:               0x0
        Cylinder High:              0x0
        Drive Head:                 0xA0
        Command:                    0xEC
    ID Sector:
        Cylinders:                  16383
        Heads:                      16
        Sectors per track:          63
        Cur Cyls:                   16383
        Cur Heads:                  16
        Cur Sectors/Track:          63
        Bytes per track:            N.A.
        Sectors per track:          N.A.
        Gen Config:                 3162
        Buffer Type:                0
        Buffer Size:                16384
        Vendor Unique:              0 0 0
        More Vendor Unique:         0x8010
        ECC Size:                   4
        Double Word IO:             0
        Capabilities:               12032
        PIO Timing:                 512
        DMA Timing:                 512
        BS:                         7
        Current Sector Capacity:    16514064
        Total Addressable Sectors:  156301488
        Mult. Sector Stuff:         272
        Single Word DMA:            0
        Multi Word DMA:             7
    That's just the drive info, here are the scan results:
    Code:
    SMART ATTRIBUTES:
     ID    Description                             Raw Value     Status        Value         Worst         Threshold     TEC
      1    Raw Read Error Rate                     0             OK            100           253           6             N.A.
      3    Spin Up Time                            0ms           OK            95            94            0             N.A.
      4    Start/Stop Count                        761           OK            100           100           20            N.A.
      5    Reallocated Sector Count                62869         FAIL          1             1             36            N.A.
      7    Seek Error Rate                         53447977      OK            77            60            30            N.A.
      9    Power On Time                           2711          OK            97            97            0             N.A.
      A    Spin Retry Count                        0             OK            100           100           34            N.A.
      C    Power Cycle Count                       572           OK            100           100           20            N.A.
     BB    (Unknown attribute)                     65535         OK            1             1             0             N.A.
     BD    (Unknown attribute)                     0             OK            100           100           0             N.A.
     BE    (Unknown attribute)                     740753451     OK            57            46            45            N.A.
     C0    Power off Retract Count                 72            OK            100           100           0             N.A.
     C1    Load/Unload Cycle Count                 43467         OK            79            79            0             N.A.
     C2    Temperature                             43 C          OK            43            54            0             N.A.
     C3    (Unknown attribute)                     38032146      OK            64            53            0             N.A.
     C5    Current Pending Sector Count            0             OK            100           100           0             N.A.
     C6    Uncorrectable Sector Count              0             OK            100           100           0             N.A.
     C7    UltraDMA CRC Error Count                0             OK            200           200           0             N.A.
     C8    Write Error Count                       0             OK            100           253           0             N.A.
     CA    Direct Address Mark Error Rate          0             OK            100           253           0             N.A.
    Notice the Reallocated Sector Count failed, I was wondering what might be the problem, I have been thinking that the best solution might just be to format again but I'm worried that won't do it and that there might be a simpler solution that I don't know about. Also just wondering what else looks to be a problem from these results, thanks for your help.
    It is normal for Windows (especially Vista) to access the hard drive a lot.
    It is also typical for PC's to slow down as more and more junk gets load on to them.
    What is not normal is a FAIL on the SMART data for Reallocated Sector Count. And a reformat is unlikely to fix the real problem.
    Your drive is a Seagate Momentus 5400.2. I would try and download some of the Seagate tools to see if you can get any additional information, then I would look at trying to get the laptop repaired under warranty.
    • Twoiko
      • Mar 2007
      No...
      The idea is that my laptop never did this before, only since the reformat... Also, as I said, I formatted, there's MUCH less space being taken than before, when it worked fine.
        IMHO, the drive is stuffed. So even if you don't try and get it replaced, at least keep good backups.
