PC Hangs up randomly. Issues with multi-threaded testing and Test #7
  • xNimrodx
    • Aug 2016
    • 10
    So... Let me tell you the story so far....
    Been a month that my system with a Pure Black 990FX MB was giving me BSOD once every 2 days, then started to do it everyday. Decided I had enough, took the AsRock 990FX Extreme 9 out of the box (finally you could say, since it was idling in that box for months), and do a fresh install-of-all-the-things.
    Told myself "that shoud fix it!"
    ....nope
    Before scrapping the old system I went with some testing with MemTest 86+
    version 5.1 gave me errors, I mean, LOTS of errors, on the order of 400+ errors, but only on test #7. Multithread wasn't a thing, so it ran always on CPU #0.
    Attached are some screenshots that I made with my phone's camera when I stopped the tests during the first tries believing that the ram was the issue. Then I read somewhere that test #7's errors could be related to bandwith issues between the MB and the DIMMS. So I ran more tests just to get more errors, but only on that test, #7
    I ran the tests this way: tested every single DIMM alone, then all togheter. Only test #7 gave me issues. Test #10 blocked my system entirely.
    Read somewhere that multithread support wasn't a thing on the 5.1 v of the program and that test #7 had some issues too, so I said "don't care, let's just go for the new MB at this point and test things there". So I did.
    After installing and updating every bit of windows and drivers, the pc hangs up again.. it does that usually after hours of work without issues. Randomly. And without saying a thing, like, leaving me completely clueless. It just freezes and that's it.
    So, more tests.
    Downloaded the 7.1v of MemTest 86+, and starting to run tests.
    First issues: the program doesn't like this MB too, because it only runs on CPU #0. Tried to run tests with Parallel, no way; with R.Robin, no way; sequential goes, but it doesn't switch CPU, it stays on #0, so.... pretty much that.
    And guess what, test #7. Again. Not so many issues as with the precedent MB and the precedent version of MemTest 86+, but always different addresses, completely random. I've ran multiple passes and multiple tests and every pass of every test had some address fail here and there, random fails.
    And test 13#. But only one time. Then nevermore.
    All other tests went through without a hiccup.
    Thing is: I've run BurnIn on Torture mode for the ram, 10 processes at 10% each, and guess what, the test passed, but the system froze 20 mins later; I've run the CPU on torture mode at 100% for 4 hours and trillions of operations and not a single error. I've run a Torture test with the GPU, the Ram and the CPU at 100%, and nothing.
    But it seems to me that if I leave the system alone, after 20 mins it freezes.
    I don't know what to think anymore. I thought it could be the PSU, it should crash my system under heavy load but it doesn't.
    I thought it could have been my CPU, but after stress testing it for 4 hours and no errors....meh.
    Thought it is the 32 GB of RAM, after all the errors with this test 7# in MemTest 86+, but....doesn't look like from BurnIn.
    Anyway, since I can't attach logs, here we got with copy-paste.
  • xNimrodx
    • Aug 2016
    • 10
    Test 13 failed, but later on it didn't anymore.
    Summary
    Report Date 2016-08-11 08:28:56
    Generated by MemTest86 V7.1 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.31
    CPU Type AMD FX-8350 Eight-Core
    CPU Clock 3991 MHz [Turbo: 4091.3 MHz]
    # Logical Processors 8
    L1 Cache 8 x 80K (36037 MB/s)
    L2 Cache 8 x 2048K (26252 MB/s)
    L3 Cache 1 x 8192K (10151 MB/s)
    Memory 32776M (4290 MB/s)
    DIMM Slot #0 8GB DDR3 XMP PC3-14900
    Corsair / CMZ32GX3M4A1866C9
    9-10-9-27 / 1866 MHz / 1.500V
    DIMM Slot #1 8GB DDR3 XMP PC3-14900
    DIMM Slot #2 8GB DDR3 XMP PC3-14900
    DIMM Slot #3 8GB DDR3 XMP PC3-14900
    Result summary
    Test Start Time 2016-08-11 04:55:56
    Elapsed Time 3:32:52
    Memory Range Tested 0x0 - 830000000 (33536MB)
    CPU Selection Mode Single: CPU # 0
    # Tests Passed 13/15 (86%)
    Lowest Error Address 0x27D8D4CCC (10200MB)
    Highest Error Address 0x7C80D2E6C (31872MB)
    Bits in Error Mask 00000000B908440F
    Bits in Error 12
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 0 [Address test, walking ones, 1 CPU] 2/2 (100%) 0
    Test 1 [Address test, own address, 1 CPU] 2/2 (100%) 0
    Test 2 [Address test, own address] 2/2 (100%) 0
    Test 3 [Moving inversions, ones & zeroes] 1/1 (100%) 0
    Test 4 [Moving inversions, 8-bit pattern] 1/1 (100%) 0
    Test 5 [Moving inversions, random pattern] 1/1 (100%) 0
    Test 6 [Block move, 64-byte blocks] 1/1 (100%) 0
    Test 7 [Moving inversions, 32-bit pattern] 0/1 (0%) 12
    Test 8 [Random number sequence] 1/1 (100%) 0
    Test 9 [Modulo 20, ones & zeros] 1/1 (100%) 0
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 1/1 (100%) 0
    Test 13 [Hammer test] 0/1 (0%) 5
    Last 10 Errors
    [Data Error] Test: 13, CPU: 0, Address: 784848E68, Expected: 2B67ECFB, Actual: 2367ECFB
    [Data Error] Test: 13, CPU: 0, Address: 748848ED0, Expected: 933DCE51, Actual: B33DCE51
    [Data Error] Test: 13, CPU: 0, Address: 6C6048994, Expected: 7EAD4345, Actual: 7EA54345
    [Data Error] Test: 13, CPU: 0, Address: 550848E00, Expected: BB5A9271, Actual: 3B5A9271
    [Data Error] Test: 13, CPU: 0, Address: 3100487EC, Expected: 5A3D5754, Actual: 5A3D5354
    [Data Error] Test: 7, CPU: 0, Address: 7C80D2E6C, Expected: F7FFFFFF, Actual: FFFFFFFF
    [Data Error] Test: 7, CPU: 0, Address: 737221374, Expected: 00000004, Actual: 00000000
    [Data Error] Test: 7, CPU: 0, Address: 5F7A01804, Expected: 00000004, Actual: 00000000
    [Data Error] Test: 7, CPU: 0, Address: 56A2DEFCC, Expected: FFFFFFFE, Actual: FFFFFFFF
    [Data Error] Test: 7, CPU: 0, Address: 5076DAFA0, Expected: 00000002, Actual: 00000000
    • xNimrodx
      • Aug 2016
      • 10
      Took almost 5 hours to run only this test, while previously it took much less time after - also - running all the rest of the tests.
      Summary
      Report Date 2016-08-11 18:21:40
      Generated by MemTest86 V7.1 Pro (64-bit)
      Result PASS
      System Information
      CPU Clock 4000 MHz [Turbo: 4000.3 MHz]
      L1 Cache 8 x 80K (35314 MB/s)
      L2 Cache 8 x 2048K (26235 MB/s)
      L3 Cache 1 x 8192K (6736 MB/s)
      Memory 32776M (2281 MB/s)
      Result summary
      Test Start Time 2016-08-11 13:36:56
      Elapsed Time 4:44:22
      # Tests Passed 1/1 (100%)
      Test 13 [Hammer test] 1/1 (100%) 0
      • xNimrodx
        • Aug 2016
        • 10
        Test #7 doesn't like me at all Summary
        Report Date 2016-08-11 20:55:23
        Result FAIL
        System Information
        Result summary
        Test Start Time 2016-08-11 19:21:21
        Elapsed Time 0:52:32
        # Tests Passed 0/1 (0%)
        Lowest Error Address 0x1DEDB5FA0 (7661MB)
        Highest Error Address 0x80F1A1730 (33009MB)
        Bits in Error Mask 000000000980D00F
        Bits in Error 10
        Test 7 [Moving inversions, 32-bit pattern] 0/1 (0%) 24
        Last 10 Errors
        [Data Error] Test: 7, CPU: 0, Address: 80F1A1730, Expected: FEFFFFFF, Actual: FFFFFFFF
        [Data Error] Test: 7, CPU: 0, Address: 7F05F4CF4, Expected: 00000001, Actual: 00000000
        [Data Error] Test: 7, CPU: 0, Address: 7BF1ED78C, Expected: 08000000, Actual: 00000000
        [Data Error] Test: 7, CPU: 0, Address: 7601A5C6C, Expected: F7FFFFFF, Actual: FFFFFFFF
        [Data Error] Test: 7, CPU: 0, Address: 6CDDF9AB0, Expected: FEFFFFFF, Actual: FFFFFFFF
        [Data Error] Test: 7, CPU: 0, Address: 6BD9AF748, Expected: 00800000, Actual: 00000000
        [Data Error] Test: 7, CPU: 0, Address: 64F1A1B80, Expected: FEFFFFFF, Actual: FFFFFFFF
        [Data Error] Test: 7, CPU: 0, Address: 56F12BD5C, Expected: FFFFBFFF, Actual: FFFFFFFF
        [Data Error] Test: 7, CPU: 0, Address: 51F9AD72C, Expected: 00001000, Actual: 00000000
        [Data Error] Test: 7, CPU: 0, Address: 4CB1A9ACC, Expected: FFFFBFFF, Actual: FFFFFFFF
        • xNimrodx
          • Aug 2016
          • 10
          BurnInTest results
          BurnInTest Version V8.1 Pro 1018
          Date Fri Aug 12 13:37:41 2016
          Logging level Normal
          System summary
          System summary
          Windows 7 Ultimate Edition Service Pack 1 build 7601 (64-bit),
          1 x AMD FX(tm)-8350 Eight-Core Processor [4001.3 MHz],
          32.0GB RAM,
          AMD Radeon HD 6870,
          233GB HDD, 466GB HDD, 2 x 932GB HDD, 279GB HDD,
          CD/DVDRW,
          General
          System Name: SHADOW
          System Model: To Be Filled By O.E.M.
          Motherboard Manufacturer: ASRock
          Motherboard Name: 990FX Extreme9
          BIOS Manufacturer: American Megatrends Inc.
          BIOS Version: P1.80
          BIOS Release Date: 03/29/2016
          BIOS Serial Number: To Be Filled By O.E.M.
          CPU
          CPU manufacturer: AuthenticAMD
          CPU Type: AMD FX(tm)-8350 Eight-Core Processor
          CPUID Family 15, Model 2, Stepping 0, Revision OR-C2
          Physical CPU's: 1
          Cores per CPU: 4
          Hyperthreading: Not capable
          CPU features: MMX SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 SSE4a DEP PAE AMD64 AES Turbo core AVX XOP FMA3 FMA4
          Clock frequencies:
          - Measured CPU speed: 4001.3 MHz [Turbo core: 4001.5MHz]
          - Multiplier: x20.0 [Turbo core: x20.0]
          - Reference Clock: 200.1 MHz
          Cache per CPU package:
          - L1 Instruction Cache: 8 x 16 KB
          - L1 data cache: 8 x 64 KB
          - L2 cache: 8 x 2 MB
          - L3 cache: 8 MB
          Memory
          Total Physical Memory: 32737MB
          Available Physical Memory: 30369MB
          Memory devices:
          Slot 1: 8GB DDR3 SDRAM PC3-14933
          Corsair CMZ32GX3M4A1866C9
          XMP: 1.50V, Clk: 933.3MHz, Timings 9-10-9-27
          Slot 2: 8GB DDR3 SDRAM PC3-14933
          Slot 3: 8GB DDR3 SDRAM PC3-14933
          Slot 4: 8GB DDR3 SDRAM PC3-14933
          Virtual memory: C:\pagefile.sys (allocated base size 4096MB)
          Memory SPD
          DIMM#0
          Memory type: DDR3 SDRAM
          SPD revision: 1.1
          Manufacturer: Corsair
          Serial number: 00000000
          Part number: CMZ32GX3M4A1866C9
          Clock speed: 666.7 MHz
          Memory size: 8192 MB
          Number of banks: 8
          Row address bits: 16
          Column address bits: 10
          Bus width: 64 bits
          Device width: 8 bits
          Number of ranks: 2
          ECC: No
          Module voltage: 1.5V
          Minimum clock cycle time (tCK): 1.500 ns
          Supported CAS latencies: 6 7 9
          Minimum CAS latency time (tAA): 13.125 ns
          Minimum RAS to CAS delay time (tRCD): 13.125 ns
          Minimum row precharge time (tRP): 13.125 ns
          Minimum active to precharge time (tRAS): 36.000 ns
          Supported timing at highest clock speed: 9-9-9-24
          Minimum Row Active to Row Active Delay (tRRD): 6.000 ns
          Minimum Active to Auto-Refresh Delay (tRC): 48.125 ns
          Minimum Recovery Delay (tRFC): 260.000 ns
          Minimum Write Recovery time (tWR): 15.000 ns
          Minimum Write to Read CMD Delay (tWTR): 7.500 ns
          Minimum Read to Pre-charge CMD Delay (tRTP): 7.500 ns
          Minimum Four Activate Window Delay (tFAW): 30.000 ns
          Operating temperature range: 0-95C
          Supports Auto Self-Refresh: No
          Supports Partial Array Self-Refresh: Yes
          Thermal Sensor present: No
          Supports On-Die Thermal Sensor readout: No
          Non-standard SDRAM type: Standard Monolithic
          Module type: UDIMM
          Module Height: 29 - 30 mm
          Module Thickness: Front: 2 - 3 mm, Back: 2 - 3 mm
          Module Width: 133.5 mm
          Reference raw card used: Raw Card B Rev. 0
          XMP Revision: 1.3
          [XMP Profile 1] Module voltage: 1.50V
          [XMP Profile 1] Clock speed: 933.3 MHz
          [XMP Profile 1] Minimum clock cycle time (tCK): 1.071 ns
          [XMP Profile 1] Supported CAS latencies: 6 9
          [XMP Profile 1] Minimum CAS latency time (tAA): 9.631 ns
          [XMP Profile 1] Minimum RAS to CAS delay time (tRCD): 10.700 ns
          [XMP Profile 1] Minimum row precharge time (tRP): 9.631 ns
          [XMP Profile 1] Minimum active to precharge time (tRAS): 28.857 ns
          [XMP Profile 1] Supported timing at highest clock speed: 9-10-9-27
          [XMP Profile 1] Minimum Row Active to Row Active Delay (tRRD): 7.500 ns
          [XMP Profile 1] Minimum Active to Auto-Refresh Delay (tRC): 50.626 ns
          [XMP Profile 1] Minimum Recovery Delay (tRFC): 260.000 ns
          [XMP Profile 1] Minimum Write Recovery time (tWR): 15.000 ns
          [XMP Profile 1] Minimum Write to Read CMD Delay (tWTR): 7.500 ns
          [XMP Profile 1] Minimum Read to Pre-charge CMD Delay (tRTP): 7.500 ns
          [XMP Profile 1] Minimum Four Activate Window Delay (tFAW): 37.500 ns
          [XMP Profile 1] Maximum tREFI Time (Average Periodic Refresh Interval): 7.786 us
          [XMP Profile 1] Write to Read CMD Turn-around Time Optimizations: No adjustment
          [XMP Profile 1] Read to Write CMD Turn-around Time Optimizations: No adjustment
          [XMP Profile 1] Back 2 Back CMD Turn-around Time Optimizations: No adjustment
          [XMP Profile 1] System CMD Rate Mode: 2N
          DIMM#1
          SPD revision: 1.1
          Number of banks: 8
          Bus width: 64 bits
          Number of ranks: 2
          ECC: No
          Module type: UDIMM
          XMP Revision: 1.3
          DIMM#2
          SPD revision: 1.1
          Number of banks: 8
          Bus width: 64 bits
          Number of ranks: 2
          ECC: No
          Module type: UDIMM
          XMP Revision: 1.3
          DIMM#3
          SPD revision: 1.1
          Number of banks: 8
          Bus width: 64 bits
          Number of ranks: 2
          ECC: No
          Module type: UDIMM
          XMP Revision: 1.3
          Graphics
          AMD Radeon HD 6870
          Chip Type: AMD Radeon Graphics Processor (0x673
          DAC Type: Internal DAC(400MHz)
          Memory: 1024MB
          BIOS: 113-3E17420-S4I
          Driver provider: Advanced Micro Devices, Inc.
          Driver version: 15.200.1062.1004
          Driver date: 8-3-2015
          Monitor 1: 1920x1080x32 60Hz (Primary monitor)
          Disk volumes
          Disk drives
          Optical drives
          Network
          Ports
          USB
          Detailed event log
          Event
          LOG NOTE: 2016-08-12 13:37:41, Status, PassMark BurnInTest V8.1 Pro 1018 (64-bit)
          LOG NOTE: 2016-08-12 13:37:42, Status, Main Tests started
          LOG NOTE: 2016-08-12 13:37:43, 3D Graphics, 3D test starting: Duty cycle = 100. Test on primary monitor (0). (x,y) = (810,429). WxH = 300x200.
          LOG NOTE: 2016-08-12 13:37:49, Memory (RAM), System Memory Total: 32737MB, Test RAM allocated: 0MB, Available: 30074MB
          LOG NOTE: 2016-08-12 13:37:51, Memory (RAM), Process 6, Test memory allocated at 0x0000000140030000 of size 3273MB
          LOG NOTE: 2016-08-12 13:37:51, Memory (RAM), Process 8, Test memory allocated at 0x0000000140030000 of size 3273MB
          LOG NOTE: 2016-08-12 13:37:51, Memory (RAM), Process 0, Test memory allocated at 0x0000000140030000 of size 3273MB
          LOG NOTE: 2016-08-12 13:37:55, Memory (RAM), Process 1, Test memory allocated at 0x0000000140030000 of size 3273MB
          LOG NOTE: 2016-08-12 13:37:55, Memory (RAM), Process 4, Test memory allocated at 0x0000000140030000 of size 3273MB
          LOG NOTE: 2016-08-12 13:37:55, Memory (RAM), Process 9, Test memory allocated at 0x0000000140030000 of size 3273MB
          LOG NOTE: 2016-08-12 13:37:55, Memory (RAM), Process 2, Test memory allocated at 0x0000000140030000 of size 3273MB
          LOG NOTE: 2016-08-12 13:37:55, Memory (RAM), Process 7, Test memory allocated at 0x0000000140030000 of size 3273MB
          LOG NOTE: 2016-08-12 13:37:56, Memory (RAM), Process 3, Test memory allocated at 0x0000000140030000 of size 3273MB
          LOG NOTE: 2016-08-12 13:37:56, Memory (RAM), Process 5, Test memory allocated at 0x0000000140030000 of size 3273MB
          WARNING: 2016-08-12 14:44:23, 3D Graphics, The 3D test was interrupted
          LOG NOTE: 2016-08-12 14:45:16, Status, Test run stopped
          Result summary
          Test Start time Fri Aug 12 13:37:41 2016
          Test Stop time Fri Aug 12 14:45:16 2016
          Test Duration 001h 07m 35s
          Test Cycles Operations Result Errors Last Error
          CPU 242 12.252 Trillion PASS 0 No errors
          Memory (RAM) 18 1.305 Trillion PASS 0 No errors
          3D Graphics 6 188460 FAIL 1 The 3D test was interrupted
          TEST RUN FAILED
          Serious error summary for the last test run
          Serious and critical errors
          No serious or critical errors
            We don't support MemTest86+.
            We only support MemTest86 (the original version).
            There is a bug in MemTest86+ V5.01. It produces false positives on Test #7.
            There are some details here,
            http://forum.canardpc.com/threads/10...kylake-i7-DDR4
            and here
            http://forum.canardpc.com/threads/97...ell-Server-bug
            It has been over a year since the bug was reported, but the author of Memtest86+ hasn't provided a fix as yet.
            But looking at the results from MemTest86 V7.1 you posted above, it does look like there is a problem.
            When you tested 1 stick at a time, where the results similar?
            Try going into BIOS and playing around with the RAM config. e.g.
            - Bump up the voltage very slightly
            - Try running with slightly slower timings
            Do you have a spare set of RAM from another vendor to try?
            • xNimrodx
              • Aug 2016
              • 10
              Unfortunately I don't have any spare set of ram of any diff. or similar vendor
              But at least I've just fixed the "freeze up" problem: for anyone interested the solution is in these 2 hotfixes
              https://support.microsoft.com/en-us/kb/2645594 (you have to install this before the other)
              https://support.microsoft.com/en-us/kb/2646060
              Turns out it was a software problem related to some AMD CPU's architecture
              But still, I can't figure out why all those issues running MemTest86 7.1
              Could only run Tests on CPU #0 (no multithread support and/or program breaks when trying to use multiple processors at once, or a different one from 0)
              Test #7 returns different/random errors
              Test #13 took hours to run compared to a precedent testrun, returned errors only in one occasion, same ram tested with BurnIn didn't return any error after torture test.
                I would ignore the one error in test #13.
                See,
                http://www.memtest86.com/troubleshooting.htm#hammer
                Some motherboard have bugs in their UEFI BIOSs that prevent multi-threading. See,
                http://www.passmark.com/forum/memtes...election-modes
                So you can ignore that as well (until new BIOS is available).
                So I think only the errors in Test #7 are off significance, and those do look like a real hardware fault. (bad RAM being the most likely cause)
                • xNimrodx
                  • Aug 2016
                  • 10
                  See,
                  But if it is bad RAM then, why are those errors always in different addresses? and why the BurnIn test for the ram passed without issues? I can't understand it.
                  Every time I've run test #7, errors appeared always in different quantities and different addresses
                    RAM timings might be marginal. So errors might appear semi randomly.
                    BurnInTest runs in Windows. So not as much RAM is available for testing in Windows.
