Always the same value of difference
  • pavel_v
    • Oct 2016
    I'm having some troubles with my PC recently, so I ran memtest86 7.1 from USB. It found quite a lot of errors. Now I'm not sure how to interpret it. Does it means something, that the difference between good and bad value is always 1000? (for example: Expected: FFFFFFFF, Actual: FFFFEFFF). This rule applies for all found errors.
    This is amount of errors:
    Test Errors
    0 0
    1 0
    2 0
    3 1
    4 891
    5 6995
    6 4680
    7 3758
    8 2163
    9 339
    10 0
    13 344
    PC specifications:
    Operating System
    Windows 10 Home 64-bit
    CPU
    Intel Core i5 6600 @ 3.30GHz 38 °C
    Skylake 14nm Technology
    RAM
    8,00GB Single-Channel Unknown @ 1200MHz (15-15-15-35)
    Motherboard
    MSI Z170A-G43 PLUS (MS-7970) (U3E1) 36 °C
    Graphics
    HP w2408 (1920x1200@60Hz)
    4096MB ATI AMD Radeon R9 380 Series (MSI) 34 °C
    Storage
    931GB Western Digital WDC WD10EALS-00Z8A0 (SATA) 38 °C
    238GB TS256GSSD370S (SSD) 26 °C
    298GB Seagate ST3320620A (ATA) 42 °C
    1863GB Seagate ST2000DM001-1ER164 (SATA) 30 °C
    596GB Western Digital WDC WD6400AAKS-65A7B0 (SATA) 37 °C
    Optical Drives
    ATAPI iHAS120 X
    Audio
    Realtek High Definition Audio
    Getting 10,000+ RAM errors is not a good thing.
    RAM is likely bad.
    It means it is a single bit error, which is the most common RAM error.
