I have been getting a blue screen stating memory management error occasionally over the last few weeks. Ran Intel Processor diagnostics and Hot CPU which both passed with no problems. Ran MemTest today and received the following results and was hoping someone could help with interpreting this, as currently I am unsure if it is an issue with RAM, mobo, PSU, or CPU:
Summary
System Information
Result summary
Summary
| Report Date | 2016-12-22 13:22:54 |
| Generated by | MemTest86 V7.2 Free (64-bit) |
| Result | FAIL |
| EFI Specifications | 2.31 |
| System | |
| Manufacturer | ASUS |
| Product Name | All Series |
| Version | System Version |
| Serial Number | System Serial Number |
| BIOS | |
| Vendor | American Megatrends Inc. |
| Version | 2304 |
| Release Date | 10/09/2014 |
| Baseboard | |
| Manufacturer | ASUSTeK COMPUTER INC. |
| Product Name | H97I-PLUS |
| Version | Rev X.0x |
| Serial Number | 140526620200925 |
| CPU Type | Intel Core i5-4690 @ 3.50GHz |
| CPU Clock | 3500 MHz [Turbo: 3900.0 MHz] |
| # Logical Processors | 4 |
| L1 Cache | 4 x 64K (183458 MB/s) |
| L2 Cache | 4 x 256K (54518 MB/s) |
| L3 Cache | 6144K (40484 MB/s) |
| Memory | 16431M (19912 MB/s) |
| DIMM Slot #0 | 8GB DDR3 PC3-12800 |
| Kingston / KHX1600C10D3/8G / 4E27E773 | |
| 10-10-10-30 / 1600 MHz / 1.5V | |
| DIMM Slot #1 | 8GB DDR3 PC3-12800 |
| Kingston / KHX1600C10D3/8G / 4C0B2006 | |
| Test Start Time | 2016-12-22 08:10:14 |
| Elapsed Time | 5:08:56 |
| Memory Range Tested | 0x0 - 41F000000 (16880MB) |
| CPU Selection Mode | Parallel (All CPUs) |
| # Tests Passed | 47/48 (97%) |
| Lowest Error Address | 0x4168CF418 (16744MB) |
| Highest Error Address | 0x4168CF418 (16744MB) |
| Bits in Error Mask | 0000000000010000 |
| Bits in Error | 1 |
| Max Contiguous Errors | 1 |
| Test | # Tests Passed | Errors |
| Test 0 [Address test, walking ones, 1 CPU] | 4/4 (100%) | 0 |
| Test 1 [Address test, own address, 1 CPU] | 4/4 (100%) | 0 |
| Test 2 [Address test, own address] | 4/4 (100%) | 0 |
| Test 3 [Moving inversions, ones & zeroes] | 4/4 (100%) | 0 |
| Test 4 [Moving inversions, 8-bit pattern] | 4/4 (100%) | 0 |
| Test 5 [Moving inversions, random pattern] | 4/4 (100%) | 0 |
| Test 6 [Block move, 64-byte blocks] | 4/4 (100%) | 0 |
| Test 7 [Moving inversions, 32-bit pattern] | 4/4 (100%) | 0 |
| Test 8 [Random number sequence] | 3/4 (75%) | 1 |
| Test 9 [Modulo 20, ones & zeros] | 4/4 (100%) | 0 |
| Test 10 [Bit fade test, 2 patterns, 1 CPU] | 4/4 (100%) | 0 |
| Test 13 [Hammer test] | 4/4 (100%) | 0 |
| Last 10 Errors |
| [Data Error] Test: 8, CPU: 2, Address: 4168CF418, Expected: 12814114, Actual: 12804114 |
