How to regain your usb drive
  • W00zZy
    • Jan 2017
    Hi, as seen recently i had RAM issues so i happily used your software to discover my issues. Now i would like to reuse my USB drive as normal but can't figure out how to regain my drive in normal state. I'm stuck with a 49Mb partition i can format, a 99Mb EFI system partition wich i can't edit/delete and 7.12Gb unallocated wich i cant assigne a new volume to.
    Any help would be kindly appreciated
    Kind regards
    Kevin
    See this post
    http://www.passmark.com/forum/memtes...with-imageUSB=
    • Origene55
      • Aug 2019
      • 8
      Hi i just found out exact this post thru google but then how about the summary that it store in the stick ?? Gone ??
      • Origene55
        • Aug 2019
        • 8
Name:	memtest86 zero start end time.jpg
        By the way it take 27mins to zero my USB stick, is that normal ?? MiniTool Partition take less than 5 mins to do the same thing
          Partitioning and wiping a drive are not the same thing.
          To create a partition you only need to to write 1 disk sector. It should take less than a second.
          Wiping the whole drive with zeros means writing to every sector on the drive. Which will take much longer.
