Memtest V7.3 Pro- Unutilised CPU Cores
  • Nano
    • Sep 2015
    • 40
    Dear Keith,
    We have purchased the Software Version: Memtest V7.3 - Pro
    The Asus Motherboard : H110 -MCS / DDR4 has 4 CPU cores but the Memetest V7.3 Pro utilises only 2 cores out of 4.
    Can all the cores be activated, If yes please let me know the procedure for the same.
    With regards,
    GAGAN SAREEN
    The Asus Motherboard ... has 4 CPU cores
    Actually it doesn't. The number of cores depends on the CPU.
    What CPU is being used?
    • Nano
      • Sep 2015
      • 40
      The CPU is Intel I 3 - 6098 P @ 3.60 GHz
        Intel Core i3-6098P is a dual core CPU.
        (hyperthreading is not used in V7.3 of MemTest86, as there was no speed advantage, but there is a config parameter to turn it on if you want)
        • Nano
          • Sep 2015
          • 40
          David,
          Memtest V7.1 , it indicated CPU Found 4, CPU started 4 and CPU active 4 but is not the same in Memtest V7.3 ??
          • Nano
            • Sep 2015
            • 40
            How do we turn it ON. Which parameter ?
              Set the 'ENABLEHT' parameter to 1 to enable hyperthreads.
              Reference: http://memtest86.com/technical.htm#config
              ENABLEHT Specifies whether to enable testing on hyperthreads. By default, memory tests are not run on hyperthreads.
              0 - Do not enable testing on hyperthreads
              1 - Enable testing on hyperthreads
              The configuration file is one of the features of the Pro Edition.
