Failure always in the same bit!
  • key
    • Mar 2017
    Hi! Windows was working fine after finishing my first PC build (which I finished yesterday), until I got a blue crash screen with "MEMORY_MANAGEMENT" error.
    After running memtest86 a few times, I noticed that the failures are always in the same bit, with the value 4 as difference:
    - Expected: 10000000, Actual: 10000400
    - Expected: FF7FFFFF, Actual: FF7FFBFF
    - Expected: 00000002, Actual: 00000402
    What does this mean? Is it surely the RAM's fault? Should I return it?
    Summary
    Report Date 2017-03-14 09:54:43
    Generated by MemTest86 V7.3 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.50
    System
    Manufacturer Gigabyte Technology Co., Ltd.
    Product Name Z270-HD3P
    Version Default string
    Serial Number Default string
    BIOS
    Version F2
    Release Date 11/25/2016
    Baseboard
    Product Name Z270-HD3P-CF
    Version x.x
    CPU Type Intel Core i7-7700K @ 4.20GHz
    CPU Clock 4201 MHz [Turbo: 4501.2 MHz]
    # Logical Processors 8 (4 enabled for testing)
    L1 Cache 4 x 64K (285432 MB/s)
    L2 Cache 4 x 256K (124595 MB/s)
    L3 Cache 8192K (67735 MB/s)
    Memory 8256M (21623 MB/s)
    DIMM Slot #0 4GB DDR4 PC4-17000
    04CD / F4-2400C15-4GVR
    2133 MHz
    DIMM Slot #1 4GB DDR4 PC4-17000
    2133 MHz
    Result summary
    Test Start Time 2017-03-14 08:11:17
    Elapsed Time 1:40:51
    Memory Range Tested 0x0 - 22F000000 (8944MB)
    # Tests Passed 34/48 (70%)
    Lowest Error Address 0x17820966C (6018MB)
    Highest Error Address 0x17FFBFDAC (6143MB)
    Bits in Error Mask 0000000000000400
    Bits in Error 1
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 3 [Moving inversions, ones & zeroes] 1/4 (25%) 7
    Test 4 [Moving inversions, 8-bit pattern] 1/4 (25%) 14
    Test 5 [Moving inversions, random pattern] 0/4 (0%) 13
    Test 7 [Moving inversions, 32-bit pattern] 0/4 (0%) 40
    Test 8 [Random number sequence] 4/4 (100%) 0
    Test 13 [Hammer test] 4/4 (100%) 0
    Last 10 Errors
    [Data Error] Test: 7, CPU: 0, Address: 17FFB8A2C, Expected: 10000000, Actual: 10000400
    [Data Error] Test: 7, CPU: 6, Address: 17BF2DDAC, Expected: 00080000, Actual: 00080400
    [Data Error] Test: 7, CPU: 6, Address: 17BF2DDEC, Expected: 00000008, Actual: 00000408
    [Data Error] Test: 7, CPU: 6, Address: 17BF2DEEC, Expected: 00000008, Actual: 00000408
    [Data Error] Test: 7, CPU: 6, Address: 17BFBFAEC, Expected: 00000002, Actual: 00000402
    [Data Error] Test: 7, CPU: 0, Address: 17C045FEC, Expected: 01000000, Actual: 01000400
    [Data Error] Test: 7, CPU: 0, Address: 17C045FAC, Expected: 00000100, Actual: 00000500
    [Data Error] Test: 7, CPU: 6, Address: 17BFBD0EC, Expected: FF7FFFFF, Actual: FF7FFBFF
    [Data Error] Test: 7, CPU: 0, Address: 17C044EEC, Expected: 00001000, Actual: 00001400
    [Data Error] Test: 7, CPU: 0, Address: 17C044EAC, Expected: 10000000, Actual: 10000400
    Certification
    This document certifies that the Tests described above have been carried out by a suitably qualified technician on the System described above.
    Signed
    ___________________________
    Put your company name here:
    Level 5, 63 Foveaux St, Surry Hills, 2010, Sydney, Australia
    Phone + 61 2 9690 0444 Fax + 61 2 9690 0445
    E-Mail: info@passmark.com
    Yes, it is likely a RAM fault.
