Same errors with 2 different ram modules
  • aquarius
    • Apr 2017
    Hi everyone!
    I made a Memtest86 7.3 UEFI test on my notebook Asus X553MA (updated to latest bios) with the original 4GB DDR3 SK Hynix HMT451S6BFR8A-PB, and it found errors on:
    Test 3 > Errors 1
    Test 4 > Errors 1
    Test 5 > Errors 1
    Test 7 > Errors 1
    Test 8 > Errors 1
    Test 9 > Errors 1
    Test 11 > Errors 1
    Test 12 > Errors 1
    Test 13 > Errors 6
    Test 0, 1, 2, 6 and 10 are OK.
    So, I change the Hynix module with a brand new Kingston 4GB DDR3 KVR16LS11/4 and it found the SAME errors on the SAME tests.
    My questions are:
    1. is there any incompatibility with that Asus motherboard ??
    2. i know that Memtest86 7.3 is better and updated than Memtest86+ 5.01 version, but why the last one found NO ERRORS at all??
    Thanks in advance.
    Can you post the details of the errors. In particular is the error address the same for all tests (and for the 2 sticks of RAM).
    There are known issues with ASUS and the multi-threading option (due to BIOS bugs). But that generally results in a crash or a freeze, not a RAM error.
    MemTest86+ V5 doesn't use UEFI. So the range of memory addresses tested in MemTest86 V7 in UEFI in different from the older non UEFI releases.
    • aquarius
      • Apr 2017
      I post you the errors from Test 13 which got six errors, but as you
      These are from Kingston 4GB DDR3
      [Data Error] Test: 13, CPU: 0, Address: 0, Expected: 3A50C3A2, Actual: 3A50C301
      [Data Error] Test: 13, CPU: 0, Address: 0, Expected: C03FAA15, Actual: C03FAA01
      [Data Error] Test: 13, CPU: 0, Address: 0, Expected: 85929AFB, Actual: 85929A01
      [Data Error] Test: 13, CPU: 0, Address: 0, Expected: CC8C1ABD, Actual: CC8C1A01
      [Data Error] Test: 13, CPU: 0, Address: 0, Expected: 49A7ABE4, Actual: 49A7AB01
      [Data Error] Test: 13, CPU: 0, Address: 0, Expected: EBE5980F, Actual: EBE59801
      These are from Hynix 4GB DDR3
      [Data Error] Test: 13, CPU: 0, Address: 0, Expected: 612237A2, Actual: 61223701
      [Data Error] Test: 13, CPU: 0, Address: 0, Expected: 80701215, Actual: 80701201
      [Data Error] Test: 13, CPU: 0, Address: 0, Expected: C24066FB, Actual: C2406601
      [Data Error] Test: 13, CPU: 0, Address: 0, Expected: 40C4CEBD, Actual: 40C4CE01
      [Data Error] Test: 13, CPU: 0, Address: 0, Expected: 386B43E4, Actual: 386B4301
      [Data Error] Test: 13, CPU: 0, Address: 0, Expected: 8A60B40F, Actual: 8A60B401
      Well, as you may notice the errors are not exactly the same as I said before, sorry, I only watched "Test number" errors.
      Second, I think you got the point, because doing again tests on Kingston and Hynix setting ONLY ONE Cpu, no more errors.
      Hope this help you.
        From the information you provided it is inconclusive.
        No errors when testing with 1 CPU might mean that the RAM doesn't get errors until it is hot. Or that there is a bad CPU core,
          The errors are from Test 13, which indicate that your RAM is susceptible to row hammer errors. See this page for details:
          http://www.memtest86.com/troubleshooting.htm#hammer
          • aquarius
            • Apr 2017
            wait... how can it be "hot" ?? the first error found is on Test #3, I think nothing could be "hot" so soon.
            could it be an issue between Asus motherboard and multi-threading as you said before??
            @ keith
            if you look up at my first message you will see that not only Test #13 got errors, but many other Tests.
              Try turning on CSM (Compatibility Support Module) in the BIOS setup.
              See this thread:
              http://www.passmark.com/forum/memtes...pu-cores/page3
