V7.3 Pro, Test 12
  • Ivan_Petrov
    • May 2017
    V7.3 Pro, Test 12
    Hi!
    When I run all tests in a row, the system is reset on the 12th test. I tried three times. When run separately, the test 12 is frozen and don't response on keys. All other tests, if exclude "test12", passed without errors. Memtest86+ 5.1 passed without errors.
    PS:My english bad i use google translate.
    Can you try running just one test thread. Also are you sure the CPU isn't overheating during the test?
    • Ivan_Petrov
      • May 2017
      This screenshot was one test thread.
      In settings, I marked only "Test 12".
      I am sure, the temperature of system and cpu is ok. I was check this. On systen is set up IPMI mail sender by malfunctions, warnings and alerts.
        The screen shot shows 16 test threads.
        • Ivan_Petrov
          • May 2017
          CPU Started: 16 CPU Active: 16 ? This you means?
          This information about cores that uses.
