Module passes in Memtest V7.3 but has no display on Gigabyte H110-MS2 motherboard.
  • Nano
    • Sep 2015
    • 40
    Hello David,
    The DDR4 - 4GB - Long Dimm module is Passing the Memtest V7.3 both on Asus Z170-K and Asus H110 MCS motherboard but this module does not give display on the Gigabyte H110-MS2 motherboard. (BIOS Version - F20 , Dated 11/16/2016).
    Please suggest the possible cause.
    Gagan
    We aren't sure what you mean by, "does not give display"?
    Can you provide more details.
    • Nano
      • Sep 2015
      • 40
      It does not Boot ..
      • Nano
        • Sep 2015
        • 40
        Dear David,
        These Modules are "ND" In Gigabyte GA H110M-S2 MB, but pass in Other MB's like Asus Z170,Z270,H110, MSI H110....
        Can you please provide me some solution for these modules... I have already Updated the MB BIOS to latest version F20.
          Maybe it is a problem with the board (and not the RAM). Does the Gigabyte board boot with different RAM from a different manufacturer?
          • Nano
            • Sep 2015
            • 40
            The Gigabyte board is OK. It is booting with different RAM
              Then likely it is a compatibility problem between that RAM and that motherboard, or maybe you have the BIOS settings incorrect for the RAM.
              • Nano
                • Sep 2015
                • 40
                Changed in BIOS under Advance memory setting - Relax OC.
                The module was working OK after keeping this setting in BIOS..
                  At the risk of stating the obvious, if the RAM fails when you overclock it, then don't overclock it.
