Is there Serial Console feature in MemTest86 V6 (or later) ?
  • xonho
    • Aug 2017
    Hi, i'm new in forum.
    'm developing a software and I need some infos:
    If the answer is positive:
    • Is there support for that feature on free version of MemTest86?
    • How can I enable that feature and configure the serial console parameters ? (For both versions , pro and free)
    Thanks in advance!
    Yes, see this page for details.
    https://www.memtest86.com/technical.htm#serial
    It can work in the Free Edition, but as there is no user interface in serial mode, you need to use the Configuration file if you want to run with any settings other than the default settings. And the configuration file is only available in the Pro version.
    • xonho
      • Aug 2017
      Thanks for the answer David (PassMark)
      I've read the the link and I've cleared my doubts. Thanks again!
