CPU temperature monitoring in MemTest86 7.4
  • bi0log
    • Sep 2017
    Hello.
    Is it normal that MemTest86 7.4 does not show CPU temp while testing?
    I've tried it on HP Probook 430 g2 with Core i3-4030U and ASUS GL752VW with Core i7-6700HQ.
    Even old MemTest86+ 5.10 does that with all Intel CPUs starting from thr first Core i generation.
    Without seeing CPU temperature there is a risk of damaging the system if it is overheatedwhile test is in progress.
    Not sure what you mean.
    Temperature of 66C is displayed in your screen shots.
    • bi0log
      • Sep 2017
      Oh.... I've missed that.. Twice...
      Thank you! )
      • bi0log
        • Sep 2017
        Again the same question - this time I've checked the screen twice before posting =)
        No temperature in a non UEFI version.
          Yes, there was no temperature reporting in V4 of the software.
          The i3-2330M CPU isn't that old, are you sure that motherboard doesn't support UEFI? (and thus allow V7 of MemTest86 to be used)
          • bi0log
            • Sep 2017
            I'll try to change boot mode to UEFI. Thank you.
