usb drive removal while test is running
  • roi32
    • Sep 2017
    hey
    Can I disconnect USB when the software runs?
    No matter which version of the software I use
    You can, MemTest86 should continue to run. However, if running V5 or later, we strongly recommend having the USB inserted into the system as the final report and a log file are written to the USB Flash Drive, which can be useful for diagnostic if there is an issue with the software.
