How to check ECC polling enable in serial console?
  • yi22588
    • Nov 2017
    I run Memtest86 on switch. Because switch doesn't have a graphic card, I can't change any configuration.
    It goes straight to testing. How to check that is ECC polling enable or not?
    Or if the program enables ECC polling automatically when it detect the memory is ECC?
    Thanks.
    Sorry, what is "switch" in this context?
    If you are running from USB drive, then there will be details in the log as to what the ECC state is.
    The RAM info displayed in your screen shot, doesn't seem to indicate that it is ECC RAM.
    • yi22588
      • Nov 2017
      Network switch. https://en.wikipedia.org/wiki/Network_switch
      I find the ECC state in log. Thanks for replying.
      2017-11-16 00:34:40 - find_mem_controller - Intel Atom C2000 SoC Transaction Router ECC mode: detect: yes, correct: yes, scrub: yes, chipkill: yes
      2017-11-16 00:34:40 - ECC polling enabled
        So not a Nintendo switch.
