UEFI Firmware can't start cpu
  • Radiologist
    • Feb 2018
    Hey guys,
    I have been trying in the last couple of days to overclock my ram. I have now an (almost) stable setting. I am sorry if this has been asked before, but I haven't been able to find anything really helpful on the internet. Here goes:
    • I ran 6 full passes straight in memtest86 (I know it might not be a full stability test, but it is a good preliminary one to see if you have a chance for prime95). I got 0 memory errors, but I had 4 times the event of the title: "UEFI Firmware cannot start cpu 5" (ryzen 5 1600). Is this concerning or can I safely ignore it? Does it mean the system is unstable? Do I just need to throw more voltage to the cpu?
    If you didn't see the error when the CPU/RAM was running at the normal clock speed, then it is a bad sign.
    If you see the error all the time, then maybe it is a BIOS firmware issues.
    • Radiologist
      • Feb 2018
      Thanks for the reply.To be honest, I haven't ran memtest @ 2666 at all, it is stock speed after all. I will do a full pass now though.
      What exactly would you mean by a "bad sign" if I don't see the event at stock speed? And if I see it again, is it safe to ignore it?
        Bad sign = the system isn't stable.
        • Radiologist
          • Feb 2018
          Right, so I ran some further tests:
          -Ran 8 consecutive full passes @3200 with more cpu and ram voltage. 0 memory errors, same UEFI errors (couldn't start cpu 5, around 8-10 of them)
          -Ran 8 consecutive full passes @ stock 2666. Exactly the same results: 0 memory errors, same UEFI errors (couldn't start cpu 5, around 8-10 of them)
          -Ran 1 full pass @2666 only on core 5. No errors at all (I guess this was expected, the core was always on and didn't need to restart).
          -Ran 10 consecutive test-6 passes @3200 for a good IMC smackdown. No errors at all.
          I would think that these UEFI errors wouldn't cause file or OS corruption long term, hence I think I want to ignore them. What do you think?
