Firts run memtest is OK, in second boot is not visible USB flash drive in boot menu
  • Ivo Popelak
    • Feb 2018
    Hello Mr,
    I created USB flash drive with Memtestx86 ver7.5. Everything was created without problem.
    I pluged flash driver to USB port in MB (MSI Z370 PC Pro, and EVGA Z270 FTW-K). When i first time started PC with boot menu, flash drive was visible and i run memtest.
    I canceled test, restart the PC and now is problem. After second loaded to boot menu i not see USB flash drive.
    I tested it on two MBs and same issue.
    I tested USB flash drive connect to USB2.0, USB3.0, front, back.
    Reformated USB flash drive = in boot menu first time was visible but on second time not.
    USB flash drive i USB2.0 16GB.
    Do you have any idea how solve this issue please?
    Is it limit of free edition of Memtest?
    Thank you very much for your help.
    With regards
    Ivo Popelak
    It isn't a known issue.
    Maybe your flash drive is failing?
