Memtest86 finished at 2 passes?
  • sharp461
    • Apr 2018
    I was also told to run at minimum 4 passes, but 7 or more is great. I downloaded the latest version and booted up into, although it booted into v4 even though I do have UEFI and I looked in BIOS for that legacy setting and I couldn't find anything, so it ran but it finished at 2 passes which I feel just ins't enough to really test it. There a way to increase passes?
    V4 runs forever, until you stop it.
    V7 runs for 4 passes, unless you change the value.
    If you have UEFI you should be able to run V7. This page might help
    https://www.memtest86.com/technical.htm#uefi
    • sharp461
      • Apr 2018
      I checked that page earlier which prompted me to check my bios, and I have the same screen in the image, but I don't have that option that's highlighted.
      I'm also wondering ow if my test was still running and never did stop even though I had a message saying finished. It was also running for 9 hours and only did 2 passes.
