Help needed with analyzing the results
  • Typonium
    • Aug 2018
    I have run Memtest86 almost a week ago on my new PC and I came across errors that I don't know how to interpret.
    Summary
    Report Date 2018-08-19 22:31:57
    Generated by MemTest86 V7.5 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.60
    System
    Manufacturer Micro-Star International Co., Ltd.
    Product Name MS-7B48
    Version 1.0
    Serial Number Default string
    BIOS
    Version 2.60
    Release Date 07/05/2018
    Baseboard
    Product Name Z370-A PRO (MS-7B4
    Version 1.0
    Serial Number I416240590
    CPU Type Intel Core i7-8700K @ 3.70GHz
    CPU Clock 3737 MHz [Turbo: 4415.8 MHz]
    # Logical Processors 12 (6 enabled for testing)
    L1 Cache 4 x 64K (237159 MB/s)
    L2 Cache 4 x 256K (103696 MB/s)
    L3 Cache 12288K (38228 MB/s)
    Memory 16351M (19258 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-23900
    Corsair / CMK16GX4M2B3000C15
    15-17-17-35 / 2998 MHz / 1.350V
    DIMM Slot #1 8GB DDR4 XMP PC4-23900
    Result summary
    Test Start Time 2018-08-19 20:16:27
    Elapsed Time 2:15:05
    Memory Range Tested 0x0 - 46F000000 (18160MB)
    ECC Polling Enabled
    # Tests Passed 30/42 (71%)
    Lowest Error Address 0x24003AE68 (9216MB)
    Highest Error Address 0x247FC65A8 (9343MB)
    Bits in Error Mask 0000000040000000
    Bits in Error 1
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 3 [Moving inversions, ones & zeroes] 3/4 (75%) 1
    Test 4 [Moving inversions, 8-bit pattern] 0/4 (0%) 14
    Test 5 [Moving inversions, random pattern] 1/4 (25%) 10
    Test 7 [Moving inversions, 32-bit pattern] 0/4 (0%) 35
    Test 8 [Random number sequence] 4/4 (100%) 0
    Test 9 [Modulo 20, ones & zeros] 3/3 (100%) 1
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 2/2 (100%) 0
    Test 13 [Hammer test] 1/1 (100%) 0
    Last 10 Errors
    [Data Error] Test: 7, CPU: 6, Address: 2400AC6A8, Expected: FFFFFFF7, Actual: BFFFFFF7
    [Data Error] Test: 7, CPU: 8, Address: 247F8CAA8, Expected: 00000004, Actual: 40000004
    [Data Error] Test: 7, CPU: 6, Address: 243FC6AA8, Expected: FFFFFFFD, Actual: BFFFFFFD
    [Data Error] Test: 7, CPU: 6, Address: 243F1D9A8, Expected: 7FFFFFFF, Actual: 3FFFFFFF
    [Data Error] Test: 7, CPU: 8, Address: 2440AA328, Expected: 10000000, Actual: 50000000
    [Data Error] Test: 7, CPU: 6, Address: 243F8EBA8, Expected: EFFFFFFF, Actual: AFFFFFFF
    [Data Error] Test: 7, CPU: 8, Address: 247F8A868, Expected: FFFFFFFD, Actual: BFFFFFFD
    [Data Error] Test: 7, CPU: 8, Address: 24411A968, Expected: 40000000, Actual: 00000000
    [Data Error] Test: 7, CPU: 6, Address: 243F53A28, Expected: FFFFFBFF, Actual: BFFFFBFF
    [Data Error] Test: 5, CPU: 8, Address: 247F8ECE8, Expected: 133FF848, Actual: 533FF848
    Certification
    This document certifies that the Tests described above have been carried out by a suitably qualified technician on the System described above.
    Signed
    If there is anything else needed I'll post them right away.
    RAM errors usually mean the RAM bad.
