test: 7 addr cpu:2 and 0 error
  • Hitcrit
    • Oct 2018
    any idea what can cause this errors? i suspect my PSU is faulty since the 12V some times get low to 11.5 and 11.6 under stress
    RAM errors are normally due to bad ram. Not the power supply. Even 11.4V is within the ATX spec however. And MemTest86 is unlikely to put very high load on the PSU. Yet you still got errors.
    DDR3 runs at 1.5V. (this is converted down from the higher voltages the PSU supplies)
    • Hitcrit
      • Oct 2018
      thank you for yoyr help! but i still don’t get it is it ram error or cpu error! and where does the problem come from? plus my rams are XMP oc to 1.65V
        Shouldn't be too hard to 'get'.
        Bad RAM sticks cause RAM errors.
