Mac Pro (2013 Trashcan) Every Slot Every module fails test 10
  • nauzers
    • Oct 2018
    Hello all.
    I bought Mac Pro for my music studio to work with audio.
    MY MAC:
    Mac Pro "Quad Core" 3.7 (Late 2013) 3.7 GHz Q. Core Xeon E5-1620v2
    Intro. October 22, 2013* Disc. April 4, 2017**
    Order ME253LL/A Model A1481 (EMC 2630)
    Family Late 2013 ID MacPro6,1
    RAM 64 GB VRAM 2 GB
    Storage 256 GB SSD Optical None*
    I was having random crashes in Logic Pro - beachballing on screensaver wakeup etc.
    I decided to test my rams with memtest86. Straight away i got many errors and without hesitation assumed they are bad and replaced them (as I was about to upgrade them anyway).
    But the problems remain. System is not stable and every now and then I get crashes and freezes.
    Now I test each ram seperately and the results are..
    RAM 1 SLOT 1 TEST 10 3078 errors
    RAM 1 SLOT 2 TEST 10 3078 errors
    RAM 1 SLOT 3 TEST 10 3078 errors
    RAM 1 SLOT 4 TEST 10 3078 errors
    RAM 2 SLOT 1 TEST 10 3078 errors
    the rest are being tested still...
    I contacted RAM supplier and they advised that all modules were tested and there is no way all 4 are bad. And most likely my CPU or CPU Riser Card is faulty. (seems to be common issue with these Macs)
    I wonder why all my RAM modules are failing Test 10 with 3078 Errors.
    Has someone had a similar issue? Could all my modules be really faulty???
    I will appreciate any support and will be responding to any suggestions / questions.
    nauzers
    It looks to be the same issues as these posts
    https://www.passmark.com/forum/memte...014-27-5k-imac
    https://www.passmark.com/forum/memte...e-2013-27-imac
    https://www.passmark.com/forum/memte...ure-on-test-10
    https://www.passmark.com/forum/memtest86/42981-macbookpro18-1-failure
    Particular Mac UEFI boot ROMS have bugs in them. See above.posts.
    We reported the issue to Apple, but they never replied. Seems they don't care.
    • nauzers
      • Oct 2018
      Hello David.
      So does it mean RAM modules are fine?
