Recovering USB Drive.
  • AndyJay
    • Nov 2018
    A couple of months back I made my USB into a bootable memtest drive. I removed the stuff off my computer and forgot about it, but now I want my USB back. I have redownloaded the memtest stuff that I originally used to create the USB drive..
    However my problem is the imageUSB is not recognising my usb. It appears under My Computer as a removable disk, but I cannot open it. Clicking on properties shows 0 bytes. I also cannot use the format feature as it says there is no disk in the drive..?
    It appears on disk management however as the image below shows I cannot do much with it. (Disk 2).
    I have tried DISKPART clean. It says there is no media in the device.
    I have also tried EaseUS and it does not show the USB drive at all.
    Is there a way to get it back?
    Drive might have gone faulty?
    Otherwise there is a topic on the issue here,
    https://www.passmark.com/forum/memte...with-imageUSB=
