Issue Viewing XMP SPD Info
  • blank_screen
    • Dec 2018
    The free version is giving an error message that XMP info is unavailable to view without an upgrade to Pro. The feature listing shows the free version supports XMP info, so I'm not sure if this is a incorrect error message or an incorrect(/unclear?) listing on the feature page.
    This is with DDR4 RAM in a Gigabyte Aorus Master Z390.
    Also is there any way to add voltage reporting? Especially with DDR4 where the new standard is 1.2V but XMP profiles can require 1.35V or higher it would be useful to see what voltage is being supplied.
    Thanks.
    XMP details should be available in the SPD data dump.
    What was the exact error message?
    • blank_screen
      • Dec 2018
      This is in MemTest86 8.0 Free.
      Under System Info, View Detailed RAM (SPD) Info, selecting a module and clicking through to see SPD info, the message at the bottom of the screen says <Additional RAM SPD info available only in Pro> / <Press any key to return to Main Menu>.
        Seems that our Features chart wasn't very clear about the SPD details.
        We have fixed it now:
        https://www.memtest86.com/features.htm
        • blank_screen
          • Dec 2018
          Thanks for the update.
