Test freeze P8BM75 in multi-core on Test #7
  • epierre
    • Jan 2019
    • 8
    Intel i3-3220
    ASUS P8B75-M
    4x4 GB G.SKILL Ripjaws X Series 1600MHz CL9 DDR3 Gaming Memory PC3-12800
    I was running the platform with 8GB, and added ram up to 16GB.
    I've had a freeze and wanted to run memtest86 v5 tests.
    Running multi-core does a freeze on test 7 block move (after 3:30mn), unitary or sequential core (several teth of hours) does not.
    Looking at forums I did upgrade MB firmware to latest with no improvements.
    Any idea of what to test ?
    There are two versions of MemTest86. Our original Memtest86 version and a old fork called Memtest86+.
    I suspect you are using the old fork of MemTest86+ V5. This isn't our software & we don't support it. It hasn't been updated in years and is known to be buggy in Test 7,
    Try the original version at https://www.memtest86.com/
    • epierre
      • Jan 2019
      • 8
      thanks for the reply, can't make 8 version start in UEFI, so I am running 4.3 which allows only 2 out of 4 cores running.
      would it be sufficient to diagnose memory ?
        According to ASUS the ASUS P8B75-M motherboard supports UEFI.
        This page might help with getting it booted.
        https://www.memtest86.com/technical.htm#uefi
        But yes, even the older releases still provide a reasonable RAM test on most systems.
        • epierre
          • Jan 2019
          • 8
          yes, finally made it working, but even there it uses only two cores on 4, on the opposite of the fork that produces the issue.
          I did run the full test ?without error, does it mean that memory is not the issue (I guess so) and that the problem may be linked to the BIOS when handling the multi-core in heavy load ?
            The i3-3220 is only a 2 core CPU.
            So if you system is still freezing in Windows, it is less likely it is the RAM (still not impossible, but less likely).
            Assuming the problem happens a lot, next steps might be to swap the video card, then try clean Windows install (after a disk backup)
            • epierre
              • Jan 2019
              • 8
              Issue I have is with Linux...
              So what I did try:
              - put the new ram alone (so 8 GB) -> stable
              - put the old in the other slots -> stable
              - put 12 GB instead of 16 GB now testing stability
              • epierre
                • Jan 2019
                • 8
                So 12 Gb is not stable under load too...
                remaining test go back to 8gb ...
                • epierre
                  • Jan 2019
                  • 8
                  well... semms ading more ram has triggered unexpected behavior, going back to original config makes the same issue now...
                  I think I'll try contact cleaning with facom spray and test again, else config is dead...
                  • epierre
                    • Jan 2019
                    • 8
                    moved everything out, graphic card, ram... did play some contact cleaner from facom everywhere and everything back in place sems fine now !
                    did run a linux stress up to 800 in load, no crash... same on io... looks resolved !
                      Thanks for the update.
                      • epierre
                        • Jan 2019
                        • 8
                        thanks for your help, I would ad the i3-3220 processor to the list of those failing on the memtest86-5.1+ incompatibilities with test 7 even if it is not under your support.
                          No point reporting bugs in the Memtest86+ version to us. We don't maintain it, and the bug have been known about for years. It is open source so anyone could fix it, but no one cares enough to do it. This is unfortunately one of the problems with open source.
                          Here is a report in their official forum for the bug in 2016
                          https://forum.canardpc.com/threads/8...running-test-7
                          and one from 2015
                          https://forum.canardpc.com/threads/9...ell-Server-bug
                          and one from 2013
                          https://forum.canardpc.com/threads/83126-5-01-freezes
