USB error after installation
  • zemonio
    • Feb 2019
    Hallo everybody,
    I was trying to use Memtest. Installed it onto an 8gb usb drive, but once I restart my computer to boot through the pendrive, no splash screen and the software doesn't start.
    But what is more important now, my pendrive has gone... The 248mb partition created by the software is impossible to remove now. I even tried many software to format, to repair or to manage the partitions. Some of them simply don't see the pendrive, others generate an error. Through windows, I just don't het any available option to manage it, so I can only use the rest of the pen now, which is divided in a total of 3 partitions (I cannot merge any).
    Did it ever happened to someone?
    This page should help you select the right boot device and options
    https://www.memtest86.com/technical.htm#uefi
    The ImageUSB installation tool that comes with MemTest86 can also wipe and reformat the drive
    https://www.passmark.com/forum/memte...with-imageUSB=
