Help?
  • Shadowfire001
    • Feb 2019
    Help?
    Summary
    Report Date 2019-02-24 21:36:22
    Generated by MemTest86 V8.1 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.60
    System
    Manufacturer MSI
    Product Name MS-7A63
    Version 1.0
    Serial Number Default string
    BIOS
    Version 1.40
    Release Date 03/31/2017
    Baseboard
    Manufacturer MSI
    Product Name Z270 GAMING PRO CARBON (MS-7A63)
    Version 1.0
    Serial Number H516100217
    CPU Type Intel Core i7-7700K @ 4.20GHz
    CPU Clock 4201 MHz [Turbo: 4801.5 MHz]
    # Logical Processors 8 (4 enabled for testing)
    L1 Cache 4 x 64K (297605 MB/s)
    L2 Cache 4 x 256K (133475 MB/s)
    L3 Cache 8192K (74457 MB/s)
    Memory 16355M (28105 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-25600
    G Skill Intl / F4-3200C16-8GTZR
    16-18-18-38 / 3200 MHz / 1.350V
    DIMM Slot #1 8GB DDR4 XMP PC4-25600
    Result summary
    Test Start Time 2019-02-24 18:36:31
    Elapsed Time 2:31:06
    Memory Range Tested 0x0 - 46F000000 (18160MB)
    ECC Polling Enabled
    # Tests Passed 36/48 (75%)
    Lowest Error Address 0x2407B8 (2MB)
    Highest Error Address 0x46EE79EF0 (18158MB)
    Bits in Error Mask 0000000000209000
    Bits in Error 3
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 6 [Block move, 64-byte blocks] 0/4 (0%) 1001
    Test 7 [Moving inversions, 32-bit pattern] 4/4 (100%) 0
    Test 8 [Random number sequence] 0/4 (0%) 59
    Test 9 [Modulo 20, ones & zeros] 0/4 (0%) 131
    Test 13 [Hammer test] 4/4 (100%) 0
    Last 10 Errors
    2019-02-24 20:48:30 - [Data Error] Test: 9, CPU: 6, Address: 4681F3EE8, Expected: B04D49FB, Actual: B06D49FB
    2019-02-24 20:48:23 - [Data Error] Test: 9, CPU: 4, Address: 456BA37F0, Expected: 5DFEC707, Actual: 5DFED707
    2019-02-24 20:48:23 - [Data Error] Test: 9, CPU: 6, Address: 4598CB6F0, Expected: 5DFEC707, Actual: 5DFED707
    2019-02-24 20:48:23 - [Data Error] Test: 9, CPU: 2, Address: 45365B7F0, Expected: 5DFEC707, Actual: 5DFED707
    2019-02-24 20:48:23 - [Data Error] Test: 9, CPU: 2, Address: 4505A37F0, Expected: 5DFEC707, Actual: 5DFED707
    2019-02-24 20:47:43 - [Data Error] Test: 9, CPU: 2, Address: 3E3D6AEF8, Expected: 706491BF, Actual: 706481BF
    2019-02-24 20:47:42 - [Data Error] Test: 9, CPU: 2, Address: 3E3A52630, Expected: 8F9B6E40, Actual: 8F9B7E40
    2019-02-24 20:47:36 - [Data Error] Test: 9, CPU: 6, Address: 3DBB555B0, Expected: 37A5768F, Actual: 37A5668F
    2019-02-24 20:47:36 - [Data Error] Test: 9, CPU: 2, Address: 3D24AD5B0, Expected: 37A5768F, Actual: 37A5668F
    2019-02-24 20:46:32 - [Data Error] Test: 9, CPU: 0, Address: 32DEB5E38, Expected: E2CEC9E1, Actual: E2EEC9E1
    Test 13 [Hammer test] Warning
    Note: Your RAM may be vulnerable to high frequency row hammer bit flips. However the conditions needed to induce these errors occur only very rarely in normal PC usage, and so this should not be of concern to most users.
    Can someone help explain what I need to do? Whether it's trying a different slot or whether I have a faulty stick. I just need some type of response to what I should do. Any help would be much appreciated!!!!
    RAM errors normally mean the RAM is bad.
    See this page
