Please help lots of bsod while gaming or browsing and memtest86 showing errors
  • Shasidhar
    • Mar 2019
    This thing is happening since 15 days , getting random bsod errors like system service exception or irql not less or equal etc etc these bsods are occuring mostly while gaming or rendering 3d stuff and only once while browsing on Microsoft edge
    Done a few memtest86 tests getting around 115 or sometimes 118 or even 9003 errors in pass 1 itself while both ram sticks are sticked on the ram slots but while testing the ram sticks individually pass 1 and even pass 2 are getting passed without errors iam attaching some of the random snaps of the tests(2 sticks in the slots) and bsods please check them out and give me an advice thanks
    My config :- processor:- i5 7600k 3.80 ghz
    Ram :- 2 ram sticks a total of 16 gb ddr4 2400 Mhz g skill ripjaws (1×8GB)
    Gpu:- nvidia gtx1060 6gb
    Motherboard:- MSI Z270 gaming m3
    I accidentally deleted some of your attachment while doing some daily spam clean up, sorry!. But from the images that I saw, it looks likely there is an error. The error looked to be a stuck bit, e.g. expected value '0xD' => (1101) but actual was '0xF' => (1111), expected value '0x5' => (0101) but actual was '0x7' => (0111).
    Check that you are using the correct slots on the motherboard. There is typically recommended configuration of which slots you should place RAM modules in. If it is in the recommend slot, you can try moving it to different slots.
    If the RAM test okay individually, possibly could be motherboard related, if you have another motherbard/machine available, you can try testing on another machine.
    • Shasidhar
      • Mar 2019
      Hi thanks for the reply i was using those ram in the same slots for 2 years and i didnt face any problem till now , so does that mean its the mother board fault or a bad ram ???
      • Shasidhar
        • Mar 2019
        I just noticed that i changed my ram slots from recommendation slots (2 months ago) , damn i didnt knew that there is something like recommendation slots for every motherboard hmm good to know , will let u know if the problem hits again even after changing the ram to recommended slots
