600+ errors tests 3-13 failed please help! v8.1
  • jmann430
    • Mar 2019
    EFI Specifications 2.60
    System
    Manufacturer System manufacturer
    Product Name System Product Name
    Version System Version
    Serial Number System Serial Number
    BIOS
    Version 4024
    Release Date 09/07/2018
    Baseboard
    Manufacturer ASUSTeK COMPUTER INC.
    Product Name ROG STRIX X470-F GAMING
    Version Rev X.0x
    Serial Number 181039216702564
    CPU Type AMD Ryzen 7 2700X Eight-Core
    CPU Clock 3716 MHz [Turbo: 4368.8 MHz]
    # Logical Processors 16
    L1 Cache 16 x 96K (101868 MB/s)
    L2 Cache 16 x 512K (83464 MB/s)
    L3 Cache 1 x 16384K (34905 MB/s)
    Memory 16329M (18579 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-25600
    G Skill Intl / F4-3200C16-8GTZRX
    16-18-18-38 / 3200 MHz / 1.350V
    DIMM Slot #1 8GB DDR4 XMP PC4-25600
    Result summary
    Test Start Time 2019-03-30 11:15:16
    Elapsed Time 3:17:49
    Memory Range Tested 0x0 - 41F380000 (16883MB)
    ECC Polling Enabled
    # Tests Passed 33/48 (68%)
    Lowest Error Address 0x221548144 (8725MB)
    Highest Error Address 0x223550858 (8757MB)
    Bits in Error Mask 0000000000000100
    Bits in Error 1
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 3 [Moving inversions, ones & zeroes] 3/4 (75%) 1
    Test 4 [Moving inversions, 8-bit pattern] 3/4 (75%) 1
    Test 5 [Moving inversions, random pattern] 3/4 (75%) 178
    Test 6 [Block move, 64-byte blocks] 3/4 (75%) 104
    Test 7 [Moving inversions, 32-bit pattern] 2/4 (50%) 227
    Test 8 [Random number sequence] 3/4 (75%) 35
    Test 9 [Modulo 20, ones & zeros] 1/4 (25%) 33
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 2/4 (50%) 151
    Test 13 [Hammer test] 1/4 (25%) 115
    Last 10 Errors
    2019-03-30 14:32:59 - [Data Error] Test: 13, CPU: 0, Address: 22154FE5C, Expected: 45C0666E, Actual: 45C0676E
    2019-03-30 14:32:59 - [Data Error] Test: 13, CPU: 0, Address: 22154FC0C, Expected: C84E5AFA, Actual: C84E5BFA
    2019-03-30 14:32:59 - [Data Error] Test: 13, CPU: 0, Address: 22154FA14, Expected: 8CAAA4C4, Actual: 8CAAA5C4
    2019-03-30 14:32:59 - [Data Error] Test: 13, CPU: 0, Address: 22154F6CC, Expected: FAB882AA, Actual: FAB883AA
    2019-03-30 14:32:59 - [Data Error] Test: 13, CPU: 0, Address: 22154F614, Expected: DAB24BC4, Actual: DAB24AC4
    2019-03-30 14:32:59 - [Data Error] Test: 13, CPU: 0, Address: 22154F294, Expected: EB42E5E4, Actual: EB42E4E4
    2019-03-30 14:32:59 - [Data Error] Test: 13, CPU: 0, Address: 22154F28C, Expected: 961B329A, Actual: 961B339A
    2019-03-30 14:32:59 - [Data Error] Test: 13, CPU: 0, Address: 22154F0C4, Expected: AC191130, Actual: AC191030
    2019-03-30 14:32:59 - [Data Error] Test: 13, CPU: 0, Address: 22154F004, Expected: AAD3ED80, Actual: AAD3EC80
    2019-03-30 14:32:59 - [Data Error] Test: 13, CPU: 0, Address: 22154EFDC, Expected: 196B2ECE, Actual: 196B2FCE
    Please help!
    • 11127
    Please help!
    Looks like bad RAM.
    See also
