MemTest86 Results Help
  • D3loFF
    • Mar 2019
    I have a new PC which often crashes on blue screen. First I've reinstalled Windows completely, but the problem persist. I performed a MemTest86 to see what will show and where is the problem. Would you help me please with the results. I did 7/8 tests and this is what I got:
    First run: Summary
    Report Date 2019-03-31 15:40:38
    Generated by MemTest86 V8.1 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.60
    System
    Manufacturer Turbo-X
    Product Name N250
    Version Default string
    Serial Number 881812911548
    BIOS
    Version F7c
    Release Date 01/16/2019
    Baseboard
    Manufacturer Gigabyte Technology Co., Ltd.
    Product Name Z390_GAMING_X
    Version x.x
    Serial Number Default string
    CPU Type Intel Core i5-9600K @ 3.70GHz
    CPU Clock 3743 MHz [Turbo: 4422.4 MHz]
    # Logical Processors 6
    L1 Cache 4 x 64K (266595 MB/s)
    L2 Cache 4 x 256K (120901 MB/s)
    L3 Cache 9216K (35841 MB/s)
    Memory 16327M (21020 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-19200
    Corsair / CMK8GX4M1A2400C16
    16-16-16-39 / 2400 MHz / 1.200V
    DIMM Slot #1 8GB DDR4 XMP PC4-19200
    Result summary
    Test Start Time 2019-03-31 13:48:06
    Elapsed Time 1:51:35
    Memory Range Tested 0x0 - 4BE000000 (19424MB)
    ECC Polling Enabled
    # Tests Passed 31/34 (91%)
    Lowest Error Address 0x18E20404 (398MB)
    Highest Error Address 0x1A626FA84 (6754MB)
    Bits in Error Mask 00000000FF000000
    Bits in Error 8
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 0 [Address test, walking ones, 1 CPU] 3/3 (100%) 0
    Test 1 [Address test, own address, 1 CPU] 3/3 (100%) 0
    Test 2 [Address test, own address] 3/3 (100%) 0
    Test 3 [Moving inversions, ones & zeroes] 3/3 (100%) 0
    Test 4 [Moving inversions, 8-bit pattern] 3/3 (100%) 0
    Test 5 [Moving inversions, random pattern] 3/3 (100%) 0
    Test 6 [Block move, 64-byte blocks] 3/3 (100%) 0
    Test 7 [Moving inversions, 32-bit pattern] 1/3 (33%) 316
    Test 8 [Random number sequence] 3/3 (100%) 0
    Test 9 [Modulo 20, ones & zeros] 2/3 (66%) 9
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 2/2 (100%) 0
    Test 13 [Hammer test] 2/2 (100%) 0
    Last 10 Errors
    2019-03-31 15:17:28 - [Data Error] Test: 7, CPU: 5, Address: 1CD4851C, Expected: FEFFFFFF, Actual: 1EFFFFFF
    2019-03-31 15:17:28 - [Data Error] Test: 7, CPU: 5, Address: 1CD48514, Expected: FFBFFFFF, Actual: 1EBFFFFF
    2019-03-31 15:17:28 - [Data Error] Test: 7, CPU: 5, Address: 1CD4850C, Expected: FFEFFFFF, Actual: 1EEFFFFF
    2019-03-31 15:17:28 - [Data Error] Test: 7, CPU: 5, Address: 1CD48504, Expected: FFFBFFFF, Actual: 1EFBFFFF
    2019-03-31 15:17:28 - [Data Error] Test: 7, CPU: 5, Address: 1CD01E3C, Expected: FFFFFFFE, Actual: 7FFFFFFE
    2019-03-31 15:17:28 - [Data Error] Test: 7, CPU: 5, Address: 1CD01E34, Expected: BFFFFFFF, Actual: DFFFFFFF
    2019-03-31 15:17:28 - [Data Error] Test: 7, CPU: 5, Address: 1CD01E2C, Expected: EFFFFFFF, Actual: F7FFFFFF
    2019-03-31 15:17:28 - [Data Error] Test: 7, CPU: 5, Address: 1CD01E24, Expected: FBFFFFFF, Actual: FDFFFFFF
    2002-03-31 15:17:28 - [Data Error] Test: 7, CPU: 5, Address: 1CD01E1C, Expected: FEFFFFFF, Actual: FFFFFFFF
    2019-03-31 15:17:28 - [Data Error] Test: 7, CPU: 5, Address: 1CD0043C, Expected: FFFFFFFE, Actual: 5BFFFFFE
    Second run: (after the test my PC just stuck and I wasn't able to retrieve the report, but I made a screenshot):
Name:	Screen Test 2.jpg
    Tell me what you think and thank you in advance.
    D3loFF
