6000+ errors. Help?
  • Ra’Hazam
    • Apr 2019
    6000+ errors. Help?
    I kept getting the Memory Management BSOD so I figured it might be a good idea to test the memory. I tested using the windows memory test, but no errors. Still getting the BSOD.
    I’m currently running the test, but this will be where I post the results.
    Pass 1 had about 6005 errors.
    Currently on Pass 2.
    Current build is as follows:
    i7-9700k
    Asus Maximus Hero XI WiFi
    G Skill Trident RGB 2x - 16gb 3200 DDR4
    EVGA 2080 Ti FTW3 Ultra
    EVGA P2 1200W platinum
    NZXT Kraken X62 AIO
    BIOS is the latest from ASUS
    Drivers were updated one by one in Device Manager.
    When using the PC to play games, run programs, or do the things, it seems to run fine. When I step away and let it idle for a few hours (about 4 when my wife saw it), it pops a BSOD Memory Management error.
    (Results to be posted after 4/4 test pass)
    • 11127
    Generally there is no need to continue testing after the first few errors.
    If you have 10 errors or 10,000 errors, the conclusion is the same.
    See
