Running MemTest86 and got lots of errors in Test 5, 6, 8, 11 items
  • phoenix
    • May 2019
    Using MemTest86 and get lots of errors in Test 8 item.
    Please check the attachments that have error for Test 8 item.
    If change to Passmark BurnIn Test and the result is PASS under Win10.
    Do you have any ideas about this?
    Look like bad RAM. Did you try swapping the RAM?
    Testing the RAM from within Windows with just 4GB of RAM isn't a great test. As the Windows O/S, video card memory mapping, disk caches, etc... will all combine to mean that nearly no free RAM is available for testing.
    • phoenix
      • May 2019
      The memory is unremovable.
      BTW, using legacy mode for MemTest86 V7.x (legacy MemTest86 version is 4.8.x) and the result is PASS
        We'll it seems it is likely there is a hardware error or firmware bug of some sort. So you either ignore it, or you fix it.
        If you have a computer that wasn't designed to be repaired and maintained, then you replace the entire machine, and maybe buy something that is repairable next time?
        We don't think it is a false error report in MemTest86, if that is what you are suggesting.
