Memtext86 quitting at test 7 due to too many errors
  • yuurei042
    • Jul 2019
    Hi guys! First time posting. I'm running into some issues that I could really use some help with.
    For the last three to four days my computer has been acting really odd - producing BSODs, locking up, etc. Ran tests on hard drives and video card, both came back ok. Decided to run Memtest86 and only got to test 7 due to the program stating that too many errors were generated. I'm having issues translating the results of the test and would love some help doing such. It looks like the report was pointing at the CPU but I'm a complete newb when it comes to reading this info. Any bit of help would be appreciated. I've included the results below. Thanks in advance!
    Summary
    Report Date 2019-07-28 11:52:58
    Generated by MemTest86 V8.2 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.60
    System
    Manufacturer System manufacturer
    Product Name System Product Name
    Version System Version
    Serial Number System Serial Number
    BIOS
    Version 0409
    Release Date 08/24/2018
    Baseboard
    Manufacturer ASUSTeK COMPUTER INC.
    Product Name PRIME B450M-A
    Version Rev X.0x
    Serial Number 181037789701422
    CPU Type AMD Ryzen 5 2600 Six-Core
    CPU Clock 3415 MHz [Turbo: 3917.2 MHz]
    # Logical Processors 12
    L1 Cache 12 x 96K (87388 MB/s)
    L2 Cache 12 x 512K (72724 MB/s)
    L3 Cache 1 x 16384K (27600 MB/s)
    Memory 16329M (14689 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-25600
    Corsair / CMK16GX4M2B3200C16
    16-18-18-36 / 3200 MHz / 1.350V
    DIMM Slot #1 8GB DDR4 XMP PC4-25600
    Result summary
    Test Start Time 2019-07-28 11:46:59
    Elapsed Time 0:05:04
    Memory Range Tested 0x0 - 41F380000 (16883MB)
    ECC Polling Enabled
    # Tests Passed 1/7 (14%)
    Lowest Error Address 0x1AD6C0140 (6870MB)
    Highest Error Address 0x1AF6C81D8 (6902MB)
    Bits in Error Mask 0000000000000A00
    Bits in Error 2
    Max Contiguous Errors 2
    Test # Tests Passed Errors
    Test 0 [Address test, walking ones, 1 CPU] 1/1 (100%) 0
    Test 1 [Address test, own address, 1 CPU] 0/1 (0%) 75
    Test 2 [Address test, own address] 0/1 (0%) 58
    Test 3 [Moving inversions, ones & zeroes] 0/1 (0%) 642
    Test 4 [Moving inversions, 8-bit pattern] 0/1 (0%) 2710
    Test 5 [Moving inversions, random pattern] 0/1 (0%) 3386
    Test 6 [Block move, 64-byte blocks] 0/1 (0%) 2820
    Test 7 [Moving inversions, 32-bit pattern] 0/0 (0%) 310
    Test 8 [Random number sequence] 0/0 (0%) 0
    Test 9 [Modulo 20, ones & zeros] 0/0 (0%) 0
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 0/0 (0%) 0
    Test 13 [Hammer test] 0/0 (0%) 0
    Last 10 Errors
    2019-07-28 11:52:02 - [Data Error] Test: 7, CPU: 8, Address: 1AD6C5040, Expected: 00010000, Actual: 00010800
    2019-07-28 11:52:02 - [Data Error] Test: 7, CPU: 8, Address: 1AD6C4FB8, Expected: 00004000, Actual: 00004800
    2019-07-28 11:52:02 - [Data Error] Test: 7, CPU: 8, Address: 1AD6C4FB0, Expected: 00001000, Actual: 00001800
    2019-07-28 11:52:02 - [Data Error] Test: 7, CPU: 8, Address: 1AD6C4DD8, Expected: 00400000, Actual: 00400800
    2019-07-28 11:52:02 - [Data Error] Test: 7, CPU: 8, Address: 1AD6C4DC0, Expected: 00010000, Actual: 00010800
    2019-07-28 11:52:02 - [Data Error] Test: 7, CPU: 8, Address: 1AD6C4D10, Expected: 00000010, Actual: 00000810
    2019-07-28 11:07:02 - [Data Error] Test: 7, CPU: 8, Address: 1AD6C4D00, Expected: 00000001, Actual: 00000801
    2019-07-28 11:52:02 - [Data Error] Test: 7, CPU: 8, Address: 1AD6C4998, Expected: 00000040, Actual: 00000840
    2019-07-28 11:52:02 - [Data Error] Test: 7, CPU: 8, Address: 1AD6C4950, Expected: 00100000, Actual: 00100800
    2019-07-28 11:52:02 - [Data Error] Test: 7, CPU: 8, Address: 1AD6C47D8, Expected: 00400000, Actual: 00400800
    • 11127
    Memory errors normally mean the RAM is bad.
    See
