Will Memtest be able to test my system?
  • jasonperrone
    • Oct 2013
    I have 64GB Ram installed. Is Memtest ok to run with that much memory?
    Yes, should be OK.
    Using V5 is preferred as it supports 64bit and doesn't need to use tricks to get access to RAM about 4GB.
    • jasonperrone
      • Oct 2013
      Yes, should be OK.
      Great, thanks David!
        Let us know if you have any problems.
