Memtest86 reboots on Dell M820 blade.
  • Crash Test Dummy
    • Oct 2013
    Hi, I have been using Memtest86 on several systems and I notice that on our Dell M820 Blades it will randomly reboot the system. I was curious since testing with Memtest86+ has no problem and runs none stop. I would use the same setup, fully populated with 8GB DDR3 RDIMM ECC modules. (Total of 48 slots with 4x CPU Intel Xeon E5-4603)
    Are you using V4 or V5 (I assume V4?)
    Does this machine support UEFI. Seem like it is fairly new, so it might. Can you try MemTest86 V5.
    How long does it run for before the reboot?
