Need Help With Memtest86 Error Results
  • H u N 2
    • Nov 2019
    • 7
    Hello everyone, I just used the MemTest86 on my Desktop. PC Specs & Problem Details below.
    PC Specs:
    AMD Ryzen 5 2600 3.40 GHz
    Asus EX-A320M-GAMING Motherboard
    Corsair Vengeance LPX 8GB (8GBX2) DDR4 2400MHz Red
    Zotac 1050ti Mini
    Antec VP500PC
    120 GB SSD, 1 Tb HDD, 500 GB HDD.
    OS: Windows 10 Professional x64
    Everything is Under Warranty and only 8-9 months old, except One DDR4 8GB Ram Module is around 2 years old.
    From last 2 weeks im getting BSOD with error codes like: Memory Management Error, SYSTEM THREAD EXCEPTION NOT HANDLED, Kernel Security Check Failure etc. Apart from BSOD My game is crashing frequently around 3-6 times with data corruption. Every time i trying to Verify and update the game to fix the corrupted data, its getting more corrupted. Sometimes my browser is crashing with " aww snap " error, sometimes applications are crashing and not responding anymore. So at first I Checked my SSD and HDD s with chkdsk. Everything was fine with storage spaces. I also checked file system with sfc command, nothing was wrong.
    Then i tried Windows Memory Diagnostics tool to check RAM condition. It was clearly mentioned that there are some problems with memory.
    After that I did some Manual RAM slotting and slotting to check that is there any problem with my Motherboard RAM slots.
    Here are the result.
    I booted the pc with One RAM Module each time, then keep switching their Location.
    RAM 1 ( OLD RAM ) Phase 1 Phase 2
    Slot 1: no boot black screen, boot fine
    Slot 2: no boot black screen, boot fine
    Slot 3: boot fine, boot fine
    Slot 4: boot fine, boot fine
    Ram 2 ( New RAM ) Phase 1 Phase 2
    Slot 1: boot fine, boot fine
    As you can see its a really weird result. I got really confuse. Right now im using New ram on 1st Slot and the old one one 3rd slot.
    Last night i used Memtest86 here are the result.
    System Information
    EFI Specifications 2.60
    System
    Manufacturer System manufacturer
    Product Name System Product Name
    Version System Version
    Serial Number System Serial Number
    BIOS
    Version 4023
    Release Date 08/20/2018
    Baseboard
    Manufacturer ASUSTeK COMPUTER INC.
    Product Name EX-A320M-GAMING
    Version Rev X.0x
    Serial Number 181037789401561
    CPU Type AMD Ryzen 5 2600 Six-Core
    CPU Clock 3415 MHz [Turbo: 3917.0 MHz]
    # Logical Processors 12
    L1 Cache 12 x 96K (87555 MB/s)
    L2 Cache 12 x 512K (68555 MB/s)
    L3 Cache 1 x 16384K (27579 MB/s)
    Memory 16329M (14865 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-19200
    Corsair / CMK8GX4M1A2400C16
    16-16-16-39 / 2400 MHz / 1.200V
    DIMM Slot #1 8GB DDR4 XMP PC4-19200
    Result summary
    Test Start Time 2019-11-08 05:43:53
    Elapsed Time 3:31:53
    Memory Range Tested 0x0 - 41F380000 (16883MB)
    ECC Polling Enabled
    # Tests Passed 27/48 (56%)
    Lowest Error Address 0x2018A0480 (8216MB)
    Highest Error Address 0x2039A77B4 (8249MB)
    Bits in Error Mask 0000000000006000
    Bits in Error 2
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 4 [Moving inversions, 8-bit pattern] 0/4 (0%) 598
    Test 5 [Moving inversions, random pattern] 2/4 (50%) 1598
    Test 6 [Block move, 64-byte blocks] 2/4 (50%) 472
    Test 7 [Moving inversions, 32-bit pattern] 1/4 (25%) 1876
    Test 8 [Random number sequence] 1/4 (25%) 15
    Test 9 [Modulo 20, ones & zeros] 1/4 (25%) 88
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 3/4 (75%) 585
    Test 13 [Hammer test] 1/4 (25%) 8
    Last 10 Errors
    2019-11-08 08:43:41 - [Data Error] Test: 9, CPU: 5, Address: 2038A6CB4, Expected: D3ADDE40, Actual: D3AD9E40
    2019-11-08 08:43:41 - [Data Error] Test: 9, CPU: 5, Address: 2038A5FE4, Expected: D3ADDE40, Actual: D3AD9E40
    2019-11-08 08:43:41 - [Data Error] Test: 9, CPU: 5, Address: 2038A4CD4, Expected: D3ADDE40, Actual: D3AD9E40
    2019-11-08 08:43:41 - [Data Error] Test: 9, CPU: 5, Address: 2038A4C34, Expected: D3ADDE40, Actual: D3AD9E40
    2019-11-08 08:43:33 - [Data Error] Test: 9, CPU: 5, Address: 2038A3934, Expected: 4F474653, Actual: 4F476653
    2019-11-08 08:43:33 - [Data Error] Test: 9, CPU: 5, Address: 2038A37A4, Expected: 4F474653, Actual: 4F472653
    2019-11-08 08:43:33 - [Data Error] Test: 9, CPU: 5, Address: 2038A3164, Expected: 4F474653, Actual: 4F476653
    2019-11-08 08:43:33 - [Data Error] Test: 9, CPU: 5, Address: 2038A2A34, Expected: 4F474653, Actual: 4F470653
    While Im posting this report here Discord App crashed, and i can not open it anymore.
    Please help me. Im scared and confused.
    And ill do single RAM Module Memtest86 test later and will post here.
    Looks like the RAM is bad.
    See.
    • H u N 2
      • Nov 2019
      • 7
      Sir do i need to run memtest86 with individual ram module ?
      Or straight go for RMA
        Is up to you.
        If you bought them as a set, then it would be normal to return them as a set.
        • H u N 2
          • Nov 2019
          • 7
          No i bought them separately, One RAM is 2 years old another one is 8 months old. Although both of them are same Corsair Vengeance LPX 8GB (8GBX2) DDR4 2400MHz
            If they need to be returned separately, then you should test them separately. But sometimes problems only occur in dual channel mode.
            • H u N 2
              • Nov 2019
              • 7
              Okay sir. Thank you for the feedback . Once im done with testing ill post the result here ..
