MemTest results - help finding out cause of issues Please.
  • divineangeal
    • Nov 2019
    I am new to the forum and frankly to all that memory mess .
    I was doing the tests because of multiple bluescreens lately which led me to here.
    I read some results which confused because on some part people said it's the CPU while to some it's RAM. I would HUGELY appreciate any help understanding my results:
    Summary
    Report Date 2019-11-10 14:32:58
    Generated by MemTest86 V8.2 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.60
    System
    Manufacturer System manufacturer
    Product Name System Product Name
    Version System Version
    Serial Number System Serial Number
    BIOS
    Version 2102
    Release Date 07/02/2019
    Baseboard
    Manufacturer ASUSTeK COMPUTER INC.
    Product Name ROG MAXIMUS X HERO
    Version Rev 1.xx
    Serial Number 170809030300244
    CPU Type Intel Core i5-9600K @ 3.70GHz
    CPU Clock 3737 MHz [Turbo: 4415.6 MHz]
    # Logical Processors 6
    L1 Cache 4 x 64K (198232 MB/s)
    L2 Cache 4 x 256K (93206 MB/s)
    L3 Cache 9216K (37192 MB/s)
    Memory 16331M (18879 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-25600
    G Skill Intl / F4-3200C16-8GTZR
    16-18-18-38 / 3200 MHz / 1.350V
    DIMM Slot #1 8GB DDR4 XMP PC4-25600
    Result summary
    Test Start Time 2019-11-10 13:07:11
    Elapsed Time 1:22:44
    Memory Range Tested 0x0 - 46F000000 (18160MB)
    ECC Polling Enabled
    # Tests Passed 26/28 (92%)
    Lowest Error Address 0x1FC31BADC (8131MB)
    Highest Error Address 0x1FE31FE00 (8163MB)
    Bits in Error Mask 0000000000040000
    Bits in Error 1
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 0 [Address test, walking ones, 1 CPU] 3/3 (100%) 0
    Test 1 [Address test, own address, 1 CPU] 3/3 (100%) 0
    Test 2 [Address test, own address] 3/3 (100%) 0
    Test 3 [Moving inversions, ones & zeroes] 3/3 (100%) 0
    Test 4 [Moving inversions, 8-bit pattern] 1/2 (50%) 6
    Test 5 [Moving inversions, random pattern] 2/2 (100%) 0
    Test 6 [Block move, 64-byte blocks] 1/2 (50%) 24
    Test 7 [Moving inversions, 32-bit pattern] 2/2 (100%) 0
    Test 8 [Random number sequence] 2/2 (100%) 0
    Test 9 [Modulo 20, ones & zeros] 2/2 (100%) 0
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 2/2 (100%) 0
    Test 13 [Hammer test] 2/2 (100%) 0
    Last 10 Errors
    2019-11-10 13:10:02 - [Data Error] Test: 6, CPU: 4, Address: 1FE31FE00, Expected: 20040000, Actual: 20000000
    2019-11-10 13:10:02 - [Data Error] Test: 6, CPU: 4, Address: 1FE31FD00, Expected: 02040000, Actual: 02000000
    2019-11-10 13:10:02 - [Data Error] Test: 6, CPU: 4, Address: 1FE31FA10, Expected: FFFBDFFF, Actual: FFFFDFFF
    2019-11-10 13:10:02 - [Data Error] Test: 6, CPU: 4, Address: 1FE31F650, Expected: 7FFBFFFF, Actual: 7FFFFFFF
    2019-11-10 13:10:02 - [Data Error] Test: 6, CPU: 4, Address: 1FE31F500, Expected: 04040000, Actual: 04000000
    2019-11-10 13:10:02 - [Data Error] Test: 6, CPU: 4, Address: 1FE31F248, Expected: 00048000, Actual: 00008000
    2019-11-10 13:10:02 - [Data Error] Test: 6, CPU: 4, Address: 1FE31EC08, Expected: 00840000, Actual: 00800000
    2019-11-10 13:10:02 - [Data Error] Test: 6, CPU: 4, Address: 1FE31E448, Expected: 02040000, Actual: 02000000
    2019-11-10 13:10:02 - [Data Error] Test: 6, CPU: 4, Address: 1FE31E318, Expected: 00140000, Actual: 00100000
    2019-11-10 13:10:02 - [Data Error] Test: 6, CPU: 4, Address: 1FE31DC58, Expected: 04040000, Actual: 04000000
    Certification
    This document certifies that the Tests described above have been carried out by a suitably qualified technician on the System described above.
    Signed
    ___________________________
    Put your company name here:
    Level 5, 63 Foveaux St, Surry Hills, 2010, Sydney, Australia
    Phone + 61 2 9690 0444 Fax + 61 2 9690 0445
    E-Mail: info@passmark.com
    Looks like bad RAM
    See also,
