MEMTEST86 not starting from Boot flash Drive
  • chesjak
    • Nov 2019
    Hi
    Trying to use memtest86
    I have created a boot flash drive as required and set BIOS to boot from F: drive.
    When I re-boot, nothing happens just a blank black screen
    What am I doing wrong??
    I have two folders on the flash drive – EFI and HELP
    HELP folder has the pdf memtest guide
    EFI has BOOT folder which has six files and BENCHMARK folder which is empty.
    I can’t believe that it is this difficult to get Memtest86 started. Must be something wrong.
    Any help appreciated
    How old is the machine?
    V8.x of MemTest86 only supports UEFI BIOS.
    If it is an old machine then you might need to go back to V4.
