is my RAM or my motherboard the problem? Memtest86
  • sijn5
    • Dec 2019
    i have some problems with my new pc like Blue screens When Running My ram in XMP. I have Run MemTest86 but can Somebody Help me make Sense of this result. do i have bad ram or is my motherboard Not supporting The Run for some Reason ?
    Summary
    Report Date 2019-12-17 14:22:43
    Generated by MemTest86 V8.3 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.70
    System
    Manufacturer System manufacturer
    Product Name System Product Name
    Version System Version
    Serial Number System Serial Number
    BIOS
    Version 1105
    Release Date 06/06/2019
    Baseboard
    Manufacturer ASUSTeK COMPUTER INC.
    Product Name ROG MAXIMUS XI HERO (WI-FI)
    Version Rev 1.xx
    Serial Number 190958550400217
    CPU Type Intel Core i9-9900K @ 3.60GHz
    CPU Clock 3645 MHz [Turbo: 4820.0 MHz]
    # Logical Processors 16 (8 enabled for testing)
    L1 Cache 4 x 64K (171205 MB/s)
    L2 Cache 4 x 256K (85297 MB/s)
    L3 Cache 16384K (42212 MB/s)
    Memory 32698M (20395 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-23900
    Corsair / CMW32GX4M4C3000C15
    15-17-17-35 / 2998 MHz / 1.350V
    DIMM Slot #1 8GB DDR4 XMP PC4-23900
    DIMM Slot #2 8GB DDR4 XMP PC4-23900
    DIMM Slot #3 8GB DDR4 XMP PC4-23900
    Result summary
    Test Start Time 2019-12-17 04:39:31
    Elapsed Time 5:47:22
    Memory Range Tested 0x0 - 86E000000 (34528MB)
    ECC Polling Enabled
    # Tests Passed 39/48 (81%)
    Lowest Error Address 0xDA32FD4 (218MB)
    Highest Error Address 0x86DEFBA94 (34526MB)
    Bits in Error Mask 00000000006C0044
    Bits in Error 6
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 6 [Block move, 64-byte blocks] 1/4 (25%) 6
    Test 7 [Moving inversions, 32-bit pattern] 4/4 (100%) 0
    Test 8 [Random number sequence] 3/4 (75%) 2
    Test 9 [Modulo 20, ones & zeros] 3/4 (75%) 1
    Test 13 [Hammer test] 0/4 (0%) 161
    Last 10 Errors
    2019-12-17 10:26:04 - [Data Error] Test: 13, CPU: 0, Address: 445F41AD4, Expected: 6E1F8464, Actual: 6E3F8464
    2019-12-17 10:23:37 - [Data Error] Test: 13, CPU: 0, Address: 3C4C62114, Expected: 295FE158, Actual: 297FE158
    2019-12-17 10:18:43 - [Data Error] Test: 13, CPU: 0, Address: 38E752114, Expected: 69DE27B7, Actual: 69FE27B7
    2019-12-17 10:18:40 - [Data Error] Test: 13, CPU: 0, Address: 240E52114, Expected: 8BF4C876, Actual: 8BD4C876
    2019-12-17 10:15:39 - [Data Error] Test: 13, CPU: 0, Address: 33C230D94, Expected: 5903A94B, Actual: 5923A94B
    2019-12-17 10:14:33 - [Data Error] Test: 13, CPU: 0, Address: 6666DFD94, Expected: 927AB190, Actual: 925AB190
    2019-12-17 10:13:17 - [Data Error] Test: 13, CPU: 0, Address: 574470854, Expected: C34DBAFB, Actual: C36DBAFB
    2019-12-17 10:13:15 - [Data Error] Test: 13, CPU: 0, Address: 483A82254, Expected: EF5F4260, Actual: EF7F4260
    2019-12-17 10:11:26 - [Data Error] Test: 13, CPU: 0, Address: 5CC016314, Expected: 96110CD0, Actual: 96310CD0
    2019-12-17 10:07:39 - [Data Error] Test: 13, CPU: 0, Address: 2A98A5914, Expected: 9D7775B4, Actual: 9D5775B4
    Very likely it is bad RAM.
    See this page
    Surprising to see so many row hammer errors in test 13. The RAM manufacturers tried to tell us this was a solved problem in DDR4.
    • sijn5
      • Dec 2019
      thanks for the info.
      I did some further testing running the RAM at 2900 MHz,I just Run The Hammer test It seems to be totally stable.
      the only whay i manage to get the ram Stable at 3000 MHz is by giving It 1.45 v, but I don't know how Good that is for the ram overtime so now It's running at 2900 MHz.
