Memtest86 Results .. Need Help to understand what going on
  • ro0st3r
    • Dec 2019
    Summary
    Report Date 2019-12-23 14:52:31
    Generated by MemTest86 V8.3 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.40
    System
    Manufacturer MSI
    Product Name MS-7978
    Version 2.0
    Serial Number Default string
    BIOS
    Version A.20
    Release Date 10/22/2015
    Baseboard
    Manufacturer MSI
    Product Name Z170A GAMING M3 (MS-797
    Version 2.0
    Serial Number FC16403937
    CPU Type Intel Core i5-6600K @ 3.50GHz
    CPU Clock 3504 MHz [Turbo: 3604.4 MHz]
    # Logical Processors 4
    L1 Cache 4 x 64K (216381 MB/s)
    L2 Cache 4 x 256K (98965 MB/s)
    L3 Cache 6144K (58612 MB/s)
    Memory 16354M (13750 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-23900
    Corsair / CMK16GX4M2B3000C15
    15-17-17-35 / 2998 MHz / 1.350V
    DIMM Slot #1 8GB DDR4 XMP PC4-23900
    Result summary
    Test Start Time 2019-12-23 09:09:35
    Elapsed Time 4:27:04
    Memory Range Tested 0x0 - 46F000000 (18160MB)
    ECC Polling Enabled
    # Tests Passed 13/48 (27%)
    Lowest Error Address 0x11987C014 (4504MB)
    Highest Error Address 0x11B87C9D0 (4536MB)
    Bits in Error Mask 0000000000000010
    Bits in Error 1
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 3 [Moving inversions, ones & zeroes] 0/4 (0%) 40
    Test 4 [Moving inversions, 8-bit pattern] 0/4 (0%) 160
    Test 5 [Moving inversions, random pattern] 0/4 (0%) 200
    Test 6 [Block move, 64-byte blocks] 0/4 (0%) 266
    Test 7 [Moving inversions, 32-bit pattern] 0/4 (0%) 638
    Test 8 [Random number sequence] 0/4 (0%) 80
    Test 9 [Modulo 20, ones & zeros] 0/4 (0%) 10
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 0/4 (0%) 4
    Test 13 [Hammer test] 1/4 (25%) 66
    Last 10 Errors
    2019-12-23 13:26:25 - [Data Error] Test: 13, CPU: 0, Address: 11987C014, Expected: 1EBF3695, Actual: 1EBF3685
    2019-12-23 13:24:03 - [Data Error] Test: 10, CPU: 0, Address: 11987C014, Expected: FFFFFFFF, Actual: FFFFFFEF
    2019-12-23 13:00:41 - [Data Error] Test: 9, CPU: 3, Address: 11987C014, Expected: 5A1187F7, Actual: 5A1187E7
    2019-12-23 12:55:41 - [Data Error] Test: 8, CPU: 3, Address: 11987C014, Expected: 466B5B36, Actual: 466B5B26
    2019-12-23 12:39:55 - [Data Error] Test: 7, CPU: 3, Address: 11987C014, Expected: FFFFFFDF, Actual: FFFFFFCF
    2019-12-23 12:34:00 - [Data Error] Test: 6, CPU: 3, Address: 11B87C590, Expected: FFF7FFEF, Actual: FFF7FFFF
    2019-12-23 12:34:00 - [Data Error] Test: 6, CPU: 3, Address: 11B87C550, Expected: FFFBFFEF, Actual: FFFBFFFF
    2019-12-23 12:34:00 - [Data Error] Test: 6, CPU: 3, Address: 11B87C510, Expected: FFFDFFEF, Actual: FFFDFFFF
    2019-12-23 12:34:00 - [Data Error] Test: 6, CPU: 3, Address: 11B87C4D0, Expected: FFFEFFEF, Actual: FFFEFFFF
    2019-12-23 12:34:00 - [Data Error] Test: 6, CPU: 3, Address: 11B87C490, Expected: FFFF7FEF, Actual: FFFF7FFF
    ___________________________
    Looks like the RAM is bad.
    See this FAQ page
