Verifying that my issue is with my memory and not with my processor
  • Spoticus
    • Dec 2019
    Good afternoon:
    I have seen that many people have received help with their test results from MemTest and I was hoping to have some help too from those that are more knowledgeable. I have completed a memtest today after receiving many BSOD's over the last several months. These happen at different times, and my stop codes are always different. I have done some software changes that were supposed to help, but to no avail. I saw that I should run a stress test and a mem test while researching today. The MemTest86 gave me plenty of errors. Below is my information.
    I believe that this confirms that my memory is bad and not my CPU, but I wanted to be sure. Can anyone help me out? I can afford to replace one or the other. I would love to not make an error in judgement. Thank you for your time and help in reading this.
    Have a great day.
    Steve
    System Information
    EFI Specifications 2.31
    System
    Manufacturer Gigabyte Technology Co., Ltd.
    Product Name Z97X-UD5H-BK
    Version To be filled by O.E.M.
    Serial Number To be filled by O.E.M.
    BIOS
    Version F8
    Release Date 09/19/2015
    Baseboard
    Version x.x
    CPU Type Intel Core i5-4690K @ 3.50GHz
    CPU Clock 3492 MHz [Turbo: 3891.0 MHz]
    # Logical Processors 4
    L1 Cache 4 x 64K (199318 MB/s)
    L2 Cache 4 x 256K (61753 MB/s)
    L3 Cache 6144K (45597 MB/s)
    Memory 16349M (17301 MB/s)
    DIMM Slot #0 8GB DDR3 XMP PC3-12800
    G Skill Intl / F3-1600C10-8GAO
    10-10-10-30 / 1600 MHz / 1.500V
    DIMM Slot #1 8GB DDR3 XMP PC3-12800
    Result summary
    Test Start Time 2019-12-28 14:18:58
    Elapsed Time 3:39:39
    Memory Range Tested 0x0 - 41F000000 (16880MB)
    ECC Polling Enabled
    # Tests Passed 35/48 (72%)
    Lowest Error Address 0x1A64DD1A8 (6756MB)
    Highest Error Address 0x1A64DD1A8 (6756MB)
    Bits in Error Mask 0000000000200000
    Bits in Error 1
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 3 [Moving inversions, ones & zeroes] 2/4 (50%) 4
    Test 4 [Moving inversions, 8-bit pattern] 1/4 (25%) 5
    Test 5 [Moving inversions, random pattern] 1/4 (25%) 5
    Test 7 [Moving inversions, 32-bit pattern] 0/4 (0%) 20
    Test 8 [Random number sequence] 3/4 (75%) 2
    Test 13 [Hammer test] 4/4 (100%) 0
    Last 10 Errors
    2019-12-28 17:13:33 - [Data Error] Test: 7, CPU: 2, Address: 1A64DD1A8, Expected: EFFFFFFF, Actual: EFDFFFFF
    2019-12-28 17:03:26 - [Data Error] Test: 5, CPU: 2, Address: 1A64DD1A8, Expected: 727D68E9, Actual: 725D68E9
    2019-12-28 16:59:42 - [Data Error] Test: 4, CPU: 2, Address: 1A64DD1A8, Expected: EFEFEFEF, Actual: EFCFEFEF
    2019-12-28 16:57:59 - [Data Error] Test: 3, CPU: 2, Address: 1A64DD1A8, Expected: FFFFFFFF, Actual: FFDFFFFF
    2019-12-28 16:12:26 - [Data Error] Test: 7, CPU: 2, Address: 1A64DD1A8, Expected: FFFFDFFF, Actual: FFDFDFFF
    2019-12-28 16:02:19 - [Data Error] Test: 5, CPU: 2, Address: 1A64DD1A8, Expected: 4DA2CA79, Actual: 4D82CA79
    2019-12-28 15:58:39 - [Data Error] Test: 4, CPU: 2, Address: 1A64DD1A8, Expected: FDFDFDFD, Actual: FDDDFDFD
    2019-12-28 15:20:51 - [Data Error] Test: 8, CPU: 2, Address: 1A64DD1A8, Expected: 363F3D5C, Actual: 361F3D5C
    2019-12-28 15:11:23 - [Data Error] Test: 7, CPU: 2, Address: 1A64DD1A8, Expected: FFEFFFFF, Actual: FFCFFFFF
    2019-12-28 15:01:17 - [Data Error] Test: 5, CPU: 2, Address: 1A64DD1A8, Expected: CFFE61F6, Actual: CFDE61F6
    RAM is likely bad.
    See,
    • Spoticus
      • Dec 2019
      Thanks for your response. I installed new RAM today and had zero errors.
