MemTest86 freezes at CPU speed estimation
  • Username123
    • Jan 2020
    Hi, I have put together a PC for a friend and installed Win 10 and all drivers, but the PC shuts down randomly and I thought there could be a problem with the RAM. I tried to run MemTest from a USB device, but it does not start (I waited for 40 minutes). Here is the log:
    2020-01-01 17:58:38 - Attempting to retrieve the root directory of the data partition.
    2020-01-01 17:58:38 - Found 2 handles that supported SimpleFileSystem
    2020-01-01 17:58:38 - Checking handle 0 (D9F8E49
    2020-01-01 17:58:38 - Handle is own partition
    2020-01-01 17:58:38 - Checking handle 1 (D9F88D9
    2020-01-01 17:58:38 - HD node found: MBR type(2), Signature type(2), Part #(2), Start LBA(51404, Num Sectors(509919)
    2020-01-01 17:58:38 - Self node: MBR type(2), Signature type(2), Part #(1), Start LBA(204, Num Sectors(509953)
    2020-01-01 17:58:38 - Disabling watchdog timer (Result: Success)
    2020-01-01 17:58:38 - Could not find Simple Network protocol.
    2020-01-01 17:58:38 - =============================================
    2020-01-01 17:58:38 - MemTest86 V8.3 Free Build: 1000 (64-bit)
    2020-01-01 17:58:38 - SMBIOS BIOS INFO Vendor: "American Megatrends Inc.", Version: "F41", Release Date: "07/30/2019"
    2020-01-01 17:58:38 - SMBIOS SYSTEM INFO Manufacturer: "Gigabyte Technology Co., Ltd.", Product: "A320M-S2H V2", Version: "Default string", S/N: "Default string", SKU: "", Family: ""
    2020-01-01 17:58:38 - SMBIOS: Found SMBIOS BaseboardInformation (pbLinAddr=0xE8E26, FormattedLen=15, iTotalLen=111)
    2020-01-01 17:58:38 - SMBIOS BASEBOARD INFO Manufacturer: "Gigabyte Technology Co., Ltd.", Product: "A320M-S2H V2-CF", Version: "x.x", S/N: "Default string", AssetTag: "Default string", LocationInChassis: "Default string"
    2020-01-01 17:58:38 - EFI Specifications: 2.70
    2020-01-01 17:58:38 - Found blacklist file
    2020-01-01 17:58:38 - [BLACKLIST] Adding "Mac-F42C88C8" (BIOS: "", FLAGS: 1) to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "Mac-F4238CC8" (BIOS: "", FLAGS: to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "Mac-27ADBB7B4CEE8E61" (BIOS: "", FLAGS: 20) to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "Mac-7BA5B2DFE22DDD8C" (BIOS: "", FLAGS: 20) to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "80AF" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "Z97MX-Gaming 5" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "Z170MX-Gaming 5" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "Z170X-Gaming 3" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "Z170X-Gaming 7" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "Z170X-Gaming GT" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "Z170X-UD3-CF" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "Z170-HD3P" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "990FXA-UD3" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "970A-DS3P" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:38 - [BLACKLIST] Adding "X99-Ultra Gaming-CF" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:39 - [BLACKLIST] Adding "M5A97 R2.0" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:39 - [BLACKLIST] Adding "M5A97 EVO R2.0" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:39 - [BLACKLIST] Adding "M5A99FX PRO R2.0" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:39 - [BLACKLIST] Adding "M5A99X EVO R2.0" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:39 - [BLACKLIST] Adding "X99-A" (BIOS: "3701", FLAGS: 2) to blacklist
    2020-01-01 17:58:39 - [BLACKLIST] Adding "X99-A/USB 3.1" (BIOS: "3701", FLAGS: 2) to blacklist
    2020-01-01 17:58:39 - [BLACKLIST] Adding "X99-A II" (BIOS: "1701", FLAGS: 2) to blacklist
    2020-01-01 17:58:39 - [BLACKLIST] Adding "X99-A" (BIOS: "1701", FLAGS: 2) to blacklist
    2020-01-01 17:58:39 - [BLACKLIST] Adding "Sabertooth X99" (BIOS: "3701", FLAGS: 2) to blacklist
    2020-01-01 17:58:39 - [BLACKLIST] Adding "SABERTOOTH 990FX R2.0" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "STRIX X99 GAMING" (BIOS: "1701", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "X99-DELUXE" (BIOS: "3701", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "X99-DELUXE II" (BIOS: "1701", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "RAMPAGE V EXTREME" (BIOS: "3701", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "MAXIMUS VIII RANGER" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "Z10PE-D8 WS" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "X9DRW" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "X9DRW-3LN4F+/X9DRW-3TF+" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "X9DRi-LN4+/X9DR3-LN4+" (BIOS: "", FLAGS: 40) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "X9DR3-F" (BIOS: "", FLAGS: 40) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "X9SRL-F" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "X9DRD-iF" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "151-BE-E097" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "131-HE-E095" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "131-HE-E095-KR" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "151-HE-E999-KR" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "PRIME B350-PLUS" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "PRIME X370-PRO" (BIOS: "", FLAGS: 4) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "CROSSHAIR VI HERO" (BIOS: "1602", FLAGS: 4) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "CROSSHAIR V FORMULA-Z" (BIOS: "", FLAGS: 4) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "ROG STRIX X370-F GAMING" (BIOS: "4012", FLAGS: 4) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "OEMSH Product" (BIOS: "", FLAGS: to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "LNVNB161216" (BIOS: "", FLAGS: to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "GA-990FX-GAMING" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "X399 SLI PLUS (MS-7B09)" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] Adding "0F685W" (BIOS: "", FLAGS: 80) to blacklist
    2020-01-01 17:58:40 - [BLACKLIST] 51 boards added to blacklist
    2020-01-01 17:58:40 - Console Control protocol workaround enabled
    2020-01-01 17:58:40 - Number of console modes: 6
    2020-01-01 17:58:40 - Mode 0: 80 x 25
    2020-01-01 17:58:40 - Mode 1: 80 x 50
    2020-01-01 17:58:40 - Mode 2: 100 x 31
    2020-01-01 17:58:40 - Mode 3: 127 x 33
    2020-01-01 17:58:40 - Mode 4: 127 x 33
    2020-01-01 17:58:40 - Mode 5: 120 x 50
    2020-01-01 17:58:41 - Initializing localization strings
    2020-01-01 17:58:41 - Language en-US is supported
    2020-01-01 17:58:41 - Language fr-FR is supported
    2020-01-01 17:58:41 - Language it-IT is supported
    2020-01-01 17:58:41 - Language es-AR is supported
    2020-01-01 17:58:41 - Language pt-BR is supported
    2020-01-01 17:58:41 - Language ca-ES is supported
    2020-01-01 17:58:41 - Language de-DE is supported
    2020-01-01 17:58:41 - Language cs-CZ is supported
    2020-01-01 17:58:41 - Language pl-PL is supported
    2020-01-01 17:58:41 - Language ru-RU is supported
    2020-01-01 17:58:41 - GetGlyph failed for character 0x3041 (Warning Unknown Glyph)
    2020-01-01 17:58:41 - Language ja-JP is not supported
    2020-01-01 17:58:41 - GetGlyph failed for character 0x4E0F (Warning Unknown Glyph)
    2020-01-01 17:58:41 - Language zh-CN is not supported
    2020-01-01 17:58:41 - GetGlyph failed for character 0xF944 (Warning Unknown Glyph)
    2020-01-01 17:58:41 - Language zh-HK is not supported
    2020-01-01 17:58:41 - Font does not support all languages. Installing unicode font...
    2020-01-01 17:58:41 - InitFont - Font header version: 1.1
    2020-01-01 17:58:41 - InitFont - Number of narrow glyphs: 6969
    2020-01-01 17:58:41 - InitFont - Number of wide glyphs: 50117
    2020-01-01 17:58:41 - Language ja-JP is supported
    2020-01-01 17:58:41 - Language zh-CN is supported
    2020-01-01 17:58:41 - Language zh-HK is supported
    2020-01-01 17:58:41 - iMS support is NOT available
    2020-01-01 17:58:42 - Initializing screen for graphics
    2020-01-01 17:58:42 - Number of graphics modes: 6
    2020-01-01 17:58:42 - Mode 0: 1280 x 960
    2020-01-01 17:58:42 - Mode 1: 640 x 480
    2020-01-01 17:58:42 - Mode 2: 800 x 600
    2020-01-01 17:58:42 - Mode 3: 1024 x 768
    2020-01-01 17:58:42 - Mode 4: 1280 x 1024
    2020-01-01 17:58:42 - Mode 5: 1920 x 1080
    2020-01-01 17:58:42 - Getting CPUID
    2020-01-01 17:58:42 - Getting cache size
    2020-01-01 17:58:42 - get_cache_size - Vendor ID: AuthenticAMD Brand ID: AMD Ryzen 3 2200G with Radeon Vega Graphics
    2020-01-01 17:58:42 - CPU CorePPack: 4 (0x00004003)
    2020-01-01 17:58:42 - L1 instruction cache size: 4 x 32KB
    2020-01-01 17:58:42 - L1 data cache size: 4 x 64KB
    2020-01-01 17:58:42 - L2 cache size: 4 x 512KB
    2020-01-01 17:58:42 - L3 cache size: 1 x 4096KB
    2020-01-01 17:58:42 - Measuring CPU/cache/mem speed
    2020-01-01 17:58:42 - hpet_init - Found RSDP. Version: 2
    2020-01-01 17:58:42 - hpet_init - Found XSDT. Entry Count: 23
    2020-01-01 17:58:42 - hpet_init - Found ACPI table: FACP Version: 6
    2020-01-01 17:58:42 - hpet_init - Found ACPI table: APIC Version: 3
    2020-01-01 17:58:42 - hpet_init - Found ACPI table: FPDT Version: 1
    2020-01-01 17:58:42 - hpet_init - Found ACPI table: FIDT Version: 1
    2020-01-01 17:58:42 - hpet_init - Found ACPI table: SSDT Version: 2
    2020-01-01 17:58:42 - hpet_init - Found ACPI table: SSDT Version: 1
    2020-01-01 17:58:42 - hpet_init - Found ACPI table: MCFG Version: 1
    2020-01-01 17:58:42 - hpet_init - Found ACPI table: HPET Version: 1
    2020-01-01 17:58:42 - hpet_init - HPET base address: 0xFED00000
    2020-01-01 17:58:42 - hpet_init - HPET gen cap: 0x429B17E10228201 (Period: 69841278fs)
    2020-01-01 17:58:42 - hpet_init - HPET gen cfg: 0x1
    2020-01-01 17:58:42 - hpet_init - main counter value (1): 279723675
    2020-01-01 17:58:42 - hpet_init - main counter value (2): 280101583
    2020-01-01 17:58:42 - cpuspeed_hpet - rdtsc instruction supported: 1
    2020-01-01 17:58:43 - cpuspeed_hpet - HPET counter start: 280857695, HPET counter end: 281573604
    2020-01-01 17:58:43 - cpuspeed_hpet - start TSC: 94021132275, end TSC: 94197362070 (difference: 176229795)
    2020-01-01 17:58:43 - cpu_cache_speed - (Attempt 1) clock cycle (ms): 3524595
    2020-01-01 17:58:43 - cpuspeed_hpet - rdtsc instruction supported: 1
    2020-01-01 17:58:43 - cpuspeed_hpet - HPET counter start: 283154570, HPET counter end: 283870479
    2020-01-01 17:58:43 - cpuspeed_hpet - start TSC: 94585978410, end TSC: 94762044755 (difference: 176066345)
    2020-01-01 17:58:43 - cpu_cache_speed - (Attempt 2) clock cycle (ms): 3521326
    2020-01-01 17:58:43 - cpuspeed_hpet - HPET counter start: 285335208, HPET counter end: 286051117
    2020-01-01 17:58:43 - cpuspeed_hpet - start TSC: 95122245085, end TSC: 95299081605 (difference: 176836520)
    2020-01-01 17:58:43 - cpu_cache_speed - (Attempt 3) clock cycle (ms): 3536730
    2020-01-01 17:58:43 - cpuspeed_hpet - HPET counter start: 287714914, HPET counter end: 288430823
    2020-01-01 17:58:44 - cpuspeed_hpet - start TSC: 95707515645, end TSC: 95883581045 (difference: 176065400)
    2020-01-01 17:58:44 - cpu_cache_speed - (Attempt 4) clock cycle (ms): 3521308
    2020-01-01 17:58:44 - cpuspeed_hpet - rdtsc instruction supported: 1
    2020-01-01 17:58:44 - cpuspeed_hpet - HPET counter start: 301507920, HPET counter end: 302223829
    2020-01-01 17:58:44 - cpuspeed_hpet - start TSC: 99101167585, end TSC: 99277233965 (difference: 176066380)
    2020-01-01 17:58:44 - cpu_cache_speed - (Attempt 5) clock cycle (ms): 3521327
    2020-01-01 17:58:44 - cpuspeed_hpet - HPET counter start: 303700894, HPET counter end: 304416803
    2020-01-01 17:58:44 - cpuspeed_hpet - start TSC: 99640492945, end TSC: 99816551695 (difference: 176058750)
    2020-01-01 17:58:44 - cpu_cache_speed - (Attempt 6) clock cycle (ms): 3521175
    2020-01-01 17:58:44 - cpu_cache_speed - Using average of last 3 samples (3521175, 3521327, 352130
    2020-01-01 17:58:44 - cpu_cache_speed - CPU speed: 3521.2MHz
    2020-01-01 17:58:44 - cpu_cache_speed - measuring L1 cache speed at 0xD6E02000 (64 KB)
    2020-01-01 17:58:44 - cpu_cache_speed - L1 cache speed: 81845 MB/s
    2020-01-01 17:58:44 - cpu_cache_speed - measuring L2 cache speed at 0xD6D92000 (512 KB)
    2020-01-01 17:58:44 - cpu_cache_speed - L2 cache speed: 59948 MB/s
    2020-01-01 17:58:45 - cpu_cache_speed - measuring L3 cache speed at 0xD642A000 (4096 KB)
    2020-01-01 17:58:45 - cpu_cache_speed - L3 cache speed: 20436 MB/s
    2020-01-01 17:58:45 - get_mem_speed - measuring mem speed at 0xD305F000 (37632 KB)
    2020-01-01 17:58:45 - get_mem_speed - mem speed: 14770 MB/s
    2020-01-01 18:12:10 - Successfully opened EFI\BOOT directory.
    2020-01-01 18:12:10 - Disabling watchdog timer (Result: Success)
    2020-01-01 18:12:10 - Could not find Simple Network protocol.
    2020-01-01 18:12:10 - =============================================
    2020-01-01 18:12:10 - MemTest86 V8.3 Free Build: 1000 (64-bit)
    2020-01-01 18:12:10 - SMBIOS BIOS INFO Vendor: "American Megatrends Inc.", Version: "F41", Release Date: "07/30/2019"
    2020-01-01 18:12:10 - SMBIOS SYSTEM INFO Manufacturer: "Gigabyte Technology Co., Ltd.", Product: "A320M-S2H V2", Version: "Default string", S/N: "Default string", SKU: "", Family: ""
    2020-01-01 18:12:10 - SMBIOS: Found SMBIOS BaseboardInformation (pbLinAddr=0xE8E26, FormattedLen=15, iTotalLen=111)
    2020-01-01 18:12:10 - SMBIOS BASEBOARD INFO Manufacturer: "Gigabyte Technology Co., Ltd.", Product: "A320M-S2H V2-CF", Version: "x.x", S/N: "Default string", AssetTag: "Default string", LocationInChassis: "Default string"
    2020-01-01 18:12:10 - EFI Specifications: 2.70
    2020-01-01 18:12:10 - Found blacklist file
    2020-01-01 18:12:10 - [BLACKLIST] Adding "Mac-F42C88C8" (BIOS: "", FLAGS: 1) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "Mac-F4238CC8" (BIOS: "", FLAGS: to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "Mac-27ADBB7B4CEE8E61" (BIOS: "", FLAGS: 20) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "Mac-7BA5B2DFE22DDD8C" (BIOS: "", FLAGS: 20) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "80AF" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "Z97MX-Gaming 5" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "Z170MX-Gaming 5" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "Z170X-Gaming 3" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "Z170X-Gaming 7" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "Z170X-Gaming GT" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "Z170X-UD3-CF" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "Z170-HD3P" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "990FXA-UD3" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "970A-DS3P" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "X99-Ultra Gaming-CF" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "M5A97 R2.0" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "M5A97 EVO R2.0" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "M5A99FX PRO R2.0" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "M5A99X EVO R2.0" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "X99-A" (BIOS: "3701", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "X99-A/USB 3.1" (BIOS: "3701", FLAGS: 2) to blacklist
    2020-01-01 18:12:10 - [BLACKLIST] Adding "X99-A II" (BIOS: "1701", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "X99-A" (BIOS: "1701", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "Sabertooth X99" (BIOS: "3701", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "SABERTOOTH 990FX R2.0" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "STRIX X99 GAMING" (BIOS: "1701", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "X99-DELUXE" (BIOS: "3701", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "X99-DELUXE II" (BIOS: "1701", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "RAMPAGE V EXTREME" (BIOS: "3701", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "MAXIMUS VIII RANGER" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "Z10PE-D8 WS" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "X9DRW" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "X9DRW-3LN4F+/X9DRW-3TF+" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "X9DRi-LN4+/X9DR3-LN4+" (BIOS: "", FLAGS: 40) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "X9DR3-F" (BIOS: "", FLAGS: 40) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "X9SRL-F" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "X9DRD-iF" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "151-BE-E097" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "131-HE-E095" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "131-HE-E095-KR" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "151-HE-E999-KR" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "PRIME B350-PLUS" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "PRIME X370-PRO" (BIOS: "", FLAGS: 4) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "CROSSHAIR VI HERO" (BIOS: "1602", FLAGS: 4) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "CROSSHAIR V FORMULA-Z" (BIOS: "", FLAGS: 4) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "ROG STRIX X370-F GAMING" (BIOS: "4012", FLAGS: 4) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "OEMSH Product" (BIOS: "", FLAGS: to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "LNVNB161216" (BIOS: "", FLAGS: to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "GA-990FX-GAMING" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "X399 SLI PLUS (MS-7B09)" (BIOS: "", FLAGS: 2) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] Adding "0F685W" (BIOS: "", FLAGS: 80) to blacklist
    2020-01-01 18:12:11 - [BLACKLIST] 51 boards added to blacklist
    Seems to crash under load.
    Maybe you forgot to apply thermal paste to the heatsink? And now it is overheating?
      Next log line should have been the calculation of the memory latency. A line like this,
      cpu_cache_speed - Memory latency:
      So for the moment I still think you should check the easy obvious stuff. Heat sink connected? CPU 8 PIN power plug connected? Try re-seating the RAM. Try A BIOS update.
