Help please reading the test
  • bhaskar.p
    • Feb 2020
    Hi please some one help me out. not sure about the meaning of these errors whether they are related to memory or the cpu. So my return period ends by tomorrow. Should i call for replacement asap?
    PS: not sure if this is the correct place to post this... but im pressed for time at the moment so sorry
    Looks likely the RAM is bad,
    See,
    • bhaskar.p
      • Feb 2020
      I'm going to go for replacement to be on safe side. By the way the errors I found came only when xmp was enabled. And not when I tested single chips. In dual channel without xmp enabled I got no errors
      • bhaskar.p
        • Feb 2020
        Ok im replacing it with thermaltake tough ram 16gb 2 sticks of 8gb. 3200mhz
        i was also considering buying hyperx fury 3200mhz. But i was only getting single sticks of 8gb no kit and thermaltake was delivering faster.
        So i was wondering when i did the memtest86 without XMP enabled i didnt get any errors on 1 passes, does that mean by motherboard and cpu are not faulty?
          Some RAM problems can be hidden by running the RAM at a slower speed (which is what turning off XMP does), or by slightly increasing voltages.
          But you shouldn't have to run the RAM slower to get it stable. This is assuming you aren't overclocking.
          • bhaskar.p
            • Feb 2020
            Got new ram for the pc, returned the old one with errors.. getting 0 errors with 4 passes. thanks for helping out
            Summary
            Report Date 2020-02-16 07:29:42
            Generated by MemTest86 V8.3 Free (64-bit)
            Result PASS
            System Information
            EFI Specifications 2.70
            System
            Manufacturer Gigabyte Technology Co., Ltd.
            Product Name B450M DS3H WIFI
            Version Default string
            Serial Number Default string
            BIOS
            Version F50
            Release Date 11/27/2019
            Baseboard
            Product Name B450M DS3H WIFI-CF
            Version x.x
            CPU Type AMD Ryzen 5 2600X Six-Core
            CPU Clock 3630 MHz [Turbo: 3629.9 MHz]
            # Logical Processors 12
            L1 Cache 12 x 96K (80372 MB/s)
            L2 Cache 12 x 512K (66266 MB/s)
            L3 Cache 1 x 16384K (30804 MB/s)
            Memory 16347M (18045 MB/s)
            DIMM Slot #0 8GB DDR4 XMP PC4-25600
            Thermaltake Technology Co Ltd / R009D408GX2-3200C16A
            16-18-18-38 / 3200 MHz / 1.350V
            DIMM Slot #1 8GB DDR4 XMP PC4-25600
            Result summary
            Test Start Time 2020-02-16 00:33:11
            Elapsed Time 3:42:22
            Memory Range Tested 0x0 - 41F380000 (16883MB)
            ECC Polling Enabled
            # Tests Passed 48/48 (100%)
            Test # Tests Passed Errors
            Test 7 [Moving inversions, 32-bit pattern] 4/4 (100%) 0
            Test 8 [Random number sequence] 4/4 (100%) 0
            Test 13 [Hammer test] 4/4 (100%) 0
