First Tests
  • Timo
    • Feb 2020
    First Tests
    I think its strange that the first test 6 there are errors and in the second test there arnt any errors?
    Im going to test my mermory 1 by 1 now.
    Im wondering is it the RAM or the CPU now?
    More likely bad RAM.
    • Timo
      • Feb 2020
      Well the reason I did this test is because I had a blue screen with the stop code memory management.
      So i did the first test.. and that were all the errors it gave me?
      I tested both RAM alone in slot 2. no errors
      After that i tried one in the 4th slot. no errors.
      Then i tried again all the slots just like my normal setup. (including the corsair vengeance rgb pro light enhancement kit) no errors.
      So i dont know what caused the blue screen cause now everything seems to be normal?
        RAM might be intermittently bad. (or bad under certain temperature / EMI conditions).
