Max cores and RAM?
  • Incubi
    • Jan 2014
    Max cores and RAM?
    Hi!
    What is the current maximum on cores and RAM?
    I'm currently testing a system with 64 cores and 256GB RAM,
    and it detects 64 CPUs, but says that only 32 CPUs started?
    Full specs are as follows:
    1x Supermicro AS-2042G-6RF
    4x AMD Opteron 16-core 6376
    16x Samsung 16GB ECC/REG 1600MHz
    Best Regards,
    Daniel Rosland
    Originally posted by Incubi
    Hi!
    Best Regards,
    Daniel Rosland
    There is a limit of 32 CPUs in the current version, V5.0.0. (V4.3.x also supports 32 cores).
    Our next release of V5.x should be able to support at least 64 cores. The maximum amount of RAM supported should be the amount that the platform can support. Let us know if this isn't the case.
