Mem errors. Need help interpreting the test!
  • dseghese
    • Mar 2020
    So, my computer was crashing for a while. Critical error, blue screen, VIDEO_TDR_FAILURE. I updated all my drivers and then my BIOS. Kept happening.
    Yesterday in one of those crashs he wouldn't reboot. The EZDEBUG light on the motherboard was on for processor and RAM. I was using 2 cards on sockets 2 and 4, as recommended by MSI. Tested each of the cards on each socket (single) and one of them only works on sockets 1 and 3 now. Cleaned every contact, same. I'm currently running both cards on 1 and 3 (in order to keep dual-channeling), ran some stress tests for a while and everything seems fine, the PC is not crashing anymore.
    BUT, now motherboard beeps on startup. One short beep which could mean memory refresh timer error. So now I ran a PassMark86 test and got one error, but I need help understanding the log. What do you think? Is the faulty card the problem? Why is it working on half the sockets while the other one works on all of them? Should I expect future trouble? Contact Kingston to replace the card?
    Anyway, thanks in advance for any help.
    EFI Specifications 2.50
    System
    Manufacturer MSI
    Product Name MS-7972
    Version 2.0
    Serial Number Default string
    BIOS
    Version A.C0
    Release Date 06/25/2018
    Baseboard
    Manufacturer MSI
    Product Name Z170M MORTAR (MS-7972)
    Version 2.0
    Serial Number FA16203850
    CPU Type Intel Core i5-6600K @ 3.50GHz
    CPU Clock 3505 MHz [Turbo: 3605.2 MHz]
    # Logical Processors 4
    L1 Cache 4 x 64K (221557 MB/s)
    L2 Cache 4 x 256K (100358 MB/s)
    L3 Cache 6144K (54057 MB/s)
    Memory 8161M (23556 MB/s)
    DIMM Slot #0 4GB DDR4 XMP PC4-21300
    Kingston / KHX2666C15D4/4G / A00D0283
    15-17-17-35 / 2666 MHz / 1.200V
    DIMM Slot #1 4GB DDR4 XMP PC4-21300
    Kingston / KHX2666C15D4/4G / A20D0283
    Result summary
    Test Start Time 2020-03-27 13:34:54
    Elapsed Time 1:37:13
    Memory Range Tested 0x0 - 26F000000 (9968MB)
    ECC Polling Enabled
    # Tests Passed 47/48 (97%)
    Lowest Error Address 0x196D345CC (6509MB)
    Highest Error Address 0x196D345CC (6509MB)
    Bits in Error Mask 0000000020000000
    Bits in Error 1
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 7 [Moving inversions, 32-bit pattern] 4/4 (100%) 0
    Test 8 [Random number sequence] 3/4 (75%) 1
    Test 13 [Hammer test] 4/4 (100%) 0
    Last 10 Errors
    2020-03-27 14:01:47 - [Data Error] Test: 8, CPU: 2, Address: 196D345CC, Expected: 164F49BD, Actual: 364F49BD
    Looks like bad RAM. See this page to start with
